Hi everyone
I'm shopping around for 6mm hub centric (66.1) wheels spacers 4x114.3 . I've found a place who will make them for $90 but I want to find a cheaper price. There's a lot of non - hub centric spacers around for a lot less.
Know of any good deals?
https://www.sau.com.au/forums/topic/467588-wheel-spacers/
you wont buy hub centric spacers that thin, 10mm will be the thinnest you will get, and as @niZmO_Man said GKTech. At the end of the day they will set you back $100 for the set off 4. Stud centric spacers are cheap for a reason. They are illegal and more dangerous.
Edited by Coullsy
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789136
23 hours ago, R-sanichi said:
Hi everyone
2 hours ago, R-sanichi said:
@Nizmo_man I tried GKTech. They only sell 10mm and thinker.
Hi I had mine made at a local engineering shop, 2 6m spacers $40, hope this easy solution helps, Jamind
Edited by jamind
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789208
OK but GK Tech 10mm are probably the best you can do off the shelf (although you will need longer studs). If you can get 4 made for $90 that is the same as Jaminds $40 for 2.
http://www.gktech.com/index.php/4-5x114-3-10mm-hub-centric-slip-on-spacers.html
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789309
This whole conversation is hurting my head.  For a start, we're looking for a cheaper price than $90 for 4x spacers.  Are these being used on an R31?  Because only R31 owners are that busted arse broke that $90 seems like you should be searching for a cheaper price.
Then there's the thought that you can even make a 6mm spacer that will correctly locate on the hub centre behind it AND provide an equivalent hub lip on the front side.....the chances of which are pretty much f**k all anyway.
Then we have the thought that, "no matter, I'll just carry on as if I hadn't been told that" and keep seeing if there is a way to get them made in New f**king Zealand, and then pay for them to be shipped to Australia, and still expect them to be less than the $90 price obtained locally.
Oh.  My.  f**king. God!
  • Like 3
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789322
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
