Hi everyone
I'm shopping around for 6mm hub centric (66.1) wheels spacers 4x114.3 . I've found a place who will make them for $90 but I want to find a cheaper price. There's a lot of non - hub centric spacers around for a lot less.
Know of any good deals?
https://www.sau.com.au/forums/topic/467588-wheel-spacers/
you wont buy hub centric spacers that thin, 10mm will be the thinnest you will get, and as @niZmO_Man said GKTech. At the end of the day they will set you back $100 for the set off 4. Stud centric spacers are cheap for a reason. They are illegal and more dangerous.
Edited by Coullsy
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789136
23 hours ago, R-sanichi said:
Hi everyone
2 hours ago, R-sanichi said:
@Nizmo_man I tried GKTech. They only sell 10mm and thinker.
Hi I had mine made at a local engineering shop, 2 6m spacers $40, hope this easy solution helps, Jamind
Edited by jamind
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789208
OK but GK Tech 10mm are probably the best you can do off the shelf (although you will need longer studs). If you can get 4 made for $90 that is the same as Jaminds $40 for 2.
http://www.gktech.com/index.php/4-5x114-3-10mm-hub-centric-slip-on-spacers.html
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789309
This whole conversation is hurting my head.  For a start, we're looking for a cheaper price than $90 for 4x spacers.  Are these being used on an R31?  Because only R31 owners are that busted arse broke that $90 seems like you should be searching for a cheaper price.
Then there's the thought that you can even make a 6mm spacer that will correctly locate on the hub centre behind it AND provide an equivalent hub lip on the front side.....the chances of which are pretty much f**k all anyway.
Then we have the thought that, "no matter, I'll just carry on as if I hadn't been told that" and keep seeing if there is a way to get them made in New f**king Zealand, and then pay for them to be shipped to Australia, and still expect them to be less than the $90 price obtained locally.
Oh.  My.  f**king. God!
  • Like 3
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789322
