Nissan Avenir PNW11 GT4-Z in the UK
Hello folks,
so, recently I picked up an Avenir GT4-Z for my missus to use as a daily, that we know of there is only 4 in the UK (2 of which I've driven, I test drove ours 3 years ago when it first came into the country funnily enough)
we are having a few issues with finding information, mainly wiring diagram stuff. - I have access to FAST so finding part numbers hasn't been too much of an issue so far.
I know with our Australian and New Zealand cousins being alot closer to Japan you tend to get some of these rare gems alot easier, and I know from my ridiculous amounts of time googling, that our Russian comrades quite like the Avenir's, I was wondering if anyone could point me in the right direction of an appropriate english speaking forum where we might be able to find some information / wiring diagrams, or if indeed any of the members on here have a GT4-Z holla at us.
only mods on the car are RS*R rear springs and we fitted some 17x9 ET25 alloys - everything else is stock so far - even down to the optional Nismo exhaust finisher
short term aims with the car, is to replace the Xanavi Navigation system with standard climate control unit and a replacement up to date double din unit, however the Xanavi unit has the air con controls integrated into the unit itself, the Stagea / Avenir air con control units have a different pinout, and thats what i'm struglling to find so I can make up a patch loom to use standard air con controls
Long term goals, I think 280 - 300 bhp would do us fine, the good thing about the GT4-Z is it comes with a Front Mount as standard, so breathing mods, decat, slight increase in boost, a fuel pump upgrade to play it safe and a remap should see that easily enough and I reckon the autobox should cope with it okay,
https://www.sau.com.au/forums/topic/467625-nissan-avenir-pnw11-gt4-z-in-the-uk/
I think for people who don't know much about these cars its worth relating it to the Nissans we do know about (because *every* Nissan is related somehow)
https://en.wikipedia.org/wiki/Nissan_Avenir
The Avenir is the successor to the U12 Bluebird and has the SR20DET (along with other engines) - can you confirm this is correct for you and you don't have one of the others (SR18DE OR CRD20T) ?
How much does it share with the U12? Any idea? It could be a good place to get info.
Wikipedia says "From May 2000 the turbocharged Salut was renamed the GT4 along with interior and exterior changes. The output of the SR20DE engine was improved." - as yours is a GT4 maybe your engine is actually the SR20DE?
a lot of higher-end jap cars integrate radio+navigation+climate control, so its not an usual problem.
A good friend of mine does a lot of stereo and TV installs in our VIP cars and to keep things relatively simple, the factory gear has to be pretty much retained. Maybe moved, but it usually causes way too many problems to remove them.
For example, he installed a larger screen with raspberry pi functionality (uses maps from your phone), BUT the old unit has been relocated to the centre console lol
I did an entire stereo in my Y34, but had to keep the factory headunit and subwoofer amp or else the system chucks the shits. The speaker wires leave the headunit and run to an AudioControl processor which takes care of business.
All I can think of is to trawl yahoo auctions and find normal AC controls with wiring (if it was offered no other spec W11's)
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
