So in February I had my car tuned making around 280rwkw. The car drove fine maybe a little carp down low, which I thought was the vct plug needing replacing.
The car then began flashing the cel/knock light. Replaced the vct plug and took it back to get the tune looked at. I've been told the car can't handle timing above 10psi and 4 degrees of timing was taken out anywhere above 10psi.
IAT were mid to high 50. Don't know if that's an issue.
Car has
Hypergear atr43ss2
Top feed rail with 1000cc xspurt
Jjr return flow cooler
Haltec platinum pro
Any reasons why a car would be fine with the timing then after a few months hate it.
Tuner thinks the 98 down here is bad but I can't see why it would be that bad/different
https://www.sau.com.au/forums/topic/467658-car-wont-take-timing-with-out-knock/
How big is your exhaust? Possibly collapsed CAT? Can you check pressure or temps pre and after intercooler?
Just saw you have a Venom cat so probably not that.
Same tuner as February?
Stao might be able to weigh in here, but I believe he was having issues with JJR Belmouth dump pupes at one stage. The flange doesnt quite match up to the gasket/turbo and you need to grind out the dump a bit to make it match.
I never had this issue but I believe that it was a problem
Do you know how much timing is actually in the MAP up were the problem area is?
Ok I don't think I had the issue as I would have noticed when I went to put the gasket on.
No I don't know how much timing is in there before after the change. I may have to see if I can find out tomorrow.
If everything was working fine for a while then it changed without notice then my bet is fuel starvation, time to check the filter, FPR, pump etc
Pump is my guess, its not delivering enough when you boost!
He did mention he took a bit of fuel out of the map as the afr was a touch rich. Would that rule out the fuel system? I didn't ask either but a pressure gauge in the fuel line would tell whether there was an issue in the fuel system wouldn't it?
When it changes from something that used to work, then it is not the fundamental architecture of the car.  If it NEVER took timing then we'd go looking at the return flow cooler, the exhaust, etc etc.  So we look to things that can change.  As has been mentioned already, cat is a possibility.  After that it's fuel system, as has also been said.  What may be happening is something unexpected like just one dirty/part blocked injector.  If you get one cylinder running a bit lean it will knock and the others won't, and the mixtures may not show up too badly because 5/6 of the engine is working right.  Those Bosch injectors may or may not have the little inlet filters in them.  They can catch crap and bock really quick.
  • Like 1
The fact the tune hadn't gone leaner would suggest it's less likely to be a fuel delivery issue which is one of the causes for this kind of thing which I've seen.  To cause THAT much sensitivity at that low boost and requested timing would need to be quite the fuelling issue, not something that would be too subtle to pick up even if it was only one cylinder - imho.
The other thing (and probably more common cause for this type of stuff) is triggering issues causing the effective timing to fly way off requested timing.   Either make sure the wiring to the CAS is good, or if you can find someone with the same type of CAS then maybe try swapping them over - or anything else you have the tech to do to rule that out.
Edited by Lithium
sorry does that mean it would be pretty obvious if there was a problem with fuel system and its most likely not the issue?
On 11/13/2016 at 0:35 AM, hypergear said:
I'm leaning towards to what the Afr gauge say as well.
do you mean if the afr was fine or rich then there isnt an issue with fuel system(injectors, FPR ect)
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
