So in February I had my car tuned making around 280rwkw. The car drove fine maybe a little carp down low, which I thought was the vct plug needing replacing.
The car then began flashing the cel/knock light. Replaced the vct plug and took it back to get the tune looked at. I've been told the car can't handle timing above 10psi and 4 degrees of timing was taken out anywhere above 10psi.
IAT were mid to high 50. Don't know if that's an issue.
Car has
Hypergear atr43ss2
Top feed rail with 1000cc xspurt
Jjr return flow cooler
Haltec platinum pro
Any reasons why a car would be fine with the timing then after a few months hate it.
Tuner thinks the 98 down here is bad but I can't see why it would be that bad/different
https://www.sau.com.au/forums/topic/467658-car-wont-take-timing-with-out-knock/
How big is your exhaust? Possibly collapsed CAT? Can you check pressure or temps pre and after intercooler?
Just saw you have a Venom cat so probably not that.
Same tuner as February?
Stao might be able to weigh in here, but I believe he was having issues with JJR Belmouth dump pupes at one stage. The flange doesnt quite match up to the gasket/turbo and you need to grind out the dump a bit to make it match.
I never had this issue but I believe that it was a problem
Do you know how much timing is actually in the MAP up were the problem area is?
Ok I don't think I had the issue as I would have noticed when I went to put the gasket on.
No I don't know how much timing is in there before after the change. I may have to see if I can find out tomorrow.
If everything was working fine for a while then it changed without notice then my bet is fuel starvation, time to check the filter, FPR, pump etc
Pump is my guess, its not delivering enough when you boost!
He did mention he took a bit of fuel out of the map as the afr was a touch rich. Would that rule out the fuel system? I didn't ask either but a pressure gauge in the fuel line would tell whether there was an issue in the fuel system wouldn't it?
When it changes from something that used to work, then it is not the fundamental architecture of the car.  If it NEVER took timing then we'd go looking at the return flow cooler, the exhaust, etc etc.  So we look to things that can change.  As has been mentioned already, cat is a possibility.  After that it's fuel system, as has also been said.  What may be happening is something unexpected like just one dirty/part blocked injector.  If you get one cylinder running a bit lean it will knock and the others won't, and the mixtures may not show up too badly because 5/6 of the engine is working right.  Those Bosch injectors may or may not have the little inlet filters in them.  They can catch crap and bock really quick.
  • Like 1
The fact the tune hadn't gone leaner would suggest it's less likely to be a fuel delivery issue which is one of the causes for this kind of thing which I've seen.  To cause THAT much sensitivity at that low boost and requested timing would need to be quite the fuelling issue, not something that would be too subtle to pick up even if it was only one cylinder - imho.
The other thing (and probably more common cause for this type of stuff) is triggering issues causing the effective timing to fly way off requested timing.   Either make sure the wiring to the CAS is good, or if you can find someone with the same type of CAS then maybe try swapping them over - or anything else you have the tech to do to rule that out.
Edited by Lithium
sorry does that mean it would be pretty obvious if there was a problem with fuel system and its most likely not the issue?
On 11/13/2016 at 0:35 AM, hypergear said:
I'm leaning towards to what the Afr gauge say as well.
do you mean if the afr was fine or rich then there isnt an issue with fuel system(injectors, FPR ect)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
