GKtech Hicas Delete
Hi i want to install  the GKteck Hicas delete in my R34 however it does not come in a kit and I need to find my own polyurethane  bushes to replace the Hicas ball joint that fits in the rear knuckle.
Does anyone know where I can get the bushes required? I only want two not an entire kit.
i have already tried GKtech they did not know, Whiteline and Redranger.
you can see the bush (orange) in photo attached.
https://www.sau.com.au/forums/topic/467662-gktech-hicas-delete/
  • 8 months later...
Hi Mate,
Not sure the super pro number but the cheapest and best way to buy the replacement bush is via GKtec.$22 each plus delivery.
Everywhere else you had to buy a set and best price I founf (for four. I only needed two) was about $120.
https://www.gktech.com/oem-rear-knuckle-bush-replacement.html
If youre in Melbourne I have spare set I can sell you for cost. Otherwise order from Gktech or pick up from one of their distributors.
GKTECH BUSHES.pdf
Thanks Eddie, i have the GK tech hicas delete kit.
The bushes were found to be faulty and loose fitting, allowing play in the arms (could be just a batch of the gk tech bushes)
I contacted a seller on ebay that sells a delete kit with superpro bushes and they told me the part number was spf1638k.
It should come in next week, will post whether it fits or not.
