GKtech Hicas Delete
Hi i want to install  the GKteck Hicas delete in my R34 however it does not come in a kit and I need to find my own polyurethane  bushes to replace the Hicas ball joint that fits in the rear knuckle.
Does anyone know where I can get the bushes required? I only want two not an entire kit.
i have already tried GKtech they did not know, Whiteline and Redranger.
you can see the bush (orange) in photo attached.
https://www.sau.com.au/forums/topic/467662-gktech-hicas-delete/
  • 8 months later...
Hi Mate,
Not sure the super pro number but the cheapest and best way to buy the replacement bush is via GKtec.$22 each plus delivery.
Everywhere else you had to buy a set and best price I founf (for four. I only needed two) was about $120.
https://www.gktech.com/oem-rear-knuckle-bush-replacement.html
If youre in Melbourne I have spare set I can sell you for cost. Otherwise order from Gktech or pick up from one of their distributors.
GKTECH BUSHES.pdf
Thanks Eddie, i have the GK tech hicas delete kit.
The bushes were found to be faulty and loose fitting, allowing play in the arms (could be just a batch of the gk tech bushes)
I contacted a seller on ebay that sells a delete kit with superpro bushes and they told me the part number was spf1638k.
It should come in next week, will post whether it fits or not.
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
