Installing a AfterMarket TachoMeter
So guys I'm trying to install a AfterMarket Tachometer on my R34 Skyline GTT 98. It's a Autotechnica one (Picture Below)
The Tachometer has RED 12v Wire
White (Lights up the Tachometer) Wire
Black (Ground Earth) Wire
& Green ( Tacho Sensor )
Now the only problem is I can't figure out what color my Tacho Wire is on my ECU
I've looked up the diagram and it says Pin 7 but what color would it be, its hard to see and trace back.
Someone has said Green/Yellow, some say Red/Yellow but which one is it, I don't want to cut the wrong wire.
And also where would be the best place to hook up the Red Power Wire and the White Wire.
I'm installing it on my Dash Cluster to replace my current one, because my Tachometer on my Original Dash isn't working properly
so I'm using this to replace it.
Edited by Jonic
My R34 pinout says pin 5 white/black. Just had a look at the MCM video above which just happens to be on an R34 so it couldn't be easier. It appears to me that they have tapped into a black/white wire but you can just bare a bit of wire and test it without re-installing the cluster and if its right you're away. However if the problems with your tacho are caused by say a short caused by a pinched wire somewhere then you might have to go right from the ecu
R34 Pinouts with wire colours.ods
No I didn't, but the ecu wires come up to the cluster anyways, the only problem is that the after market tachometer doesn't even turn on, let alone have a rev signal. Maybe my power source or ground is not properly wired
Did you get a set of wiring instructions with the new tacho?
The thing is that, even if I didn't wire up the tachometer signal, the tachometer should turn on with just the Red wire and black wire running. But in this case it's not. Because I've wired up my tachometer wires all up but maybe got the wrong wire. I even tried my Red wire on my cigarette wire but no power still :(
The wiring instruction says
Red - 12v Power
Yellow - Illumination (Light)
Black - Ground
Green - Tachometer signal
Try your tach across the battery in case its a dud. if that's ok check that your cigarette lighter has power...preferably use a test light or multimeter (you can get them for less than $20) to identify a switched 12v source.
    • Lol a few are like that with no intention of being reborn unfortunately.
    • Done, I'll do mine soon too - whenver I take out the car next. I can cheat and make it quieter by turning off VCT at idle too - but I lose the braps
    • All trim back in wired running driving. Few things to follow up on but not far off the return to the road. att.6HN4wP38LTIOISkhA8eACoBFqzfgQMahZPLA8ut0pqE.mp4 att.w2q0ux2PGuqgQTj2Os13cNHQtqcSEcCAhD_CAXy_IQM.mp4
    • The trouble with phone apps is that they really do not know the sensitivity of the mic on each specific phone, whether there is some sort of cover or skin that can change that, etc etc. So the readings off them are not calibrated. You certainly couldn't be sure that you were even within 3 dB. I have the same app on two (actually more than that) different phones/tablets and the readings in the same room at the same time are never the same. I don't mind the apps - they are as useful as a dyno - if you're testing for delta from thing1 to thing2. But not to try to generate some sort of absolute value.
    • I'm gonna use the "Sound Meter" app from the Google Play Store and as close as I can bother to these procedures: 4. TEST METHOD FOR ALL VEHICLES EXCEPT PRE ADR83 IN-SERVICE GOODS VEHICLES AND OMNIBUSES 4.1 Microphone position 4.1.1 The microphone shall be directed towards the orifice of the exhaust outlet and shall be supported by a tripod or similar device not providing excessive acoustic reflection. The general requirements for positioning microphones are shown in the Appendix. 4.1.2 The nominal axis of maximum sensitivity of the microphone shall be substantially parallel to the test site surface and shall make an angle of 45 degrees ±10 degrees with the principal direction of gas flow from the exhaust. 4.1.3 In selecting the 45 degree alignment from the outlet of a motor vehicle fitted with two or more outlets, only the angle resulting in the microphone being farthest from any other outlet must be used. National Stationary Exhaust Noise Test Procedures for In-Service Motor Vehicles Page 3 4.1.4 The height of the microphone above the test site surface shall be equal to that of the orifice of the exhaust outlet ±25mm but shall not be less than 200mm above the test site surface. 4.1.5 The distance of the microphone from the exhaust outlet orifice shall be 500mm±25mm. 4.1.6 [Relates to vertical exhaust outlets] 4.1.7 For vehicles fitted with one exhaust outlet the microphone shall be placed so that the greatest possible distance is achieved between it and the vehicle. 4.1.8 [Relates to multi exhaust outlets] 4.1.9 [Relates to multi exhaust outlets] TLDR: 200mm off ground 45 degree angle relative to exhaust flow 500mm from tailpipe exit. (I probably won't use a tripod) Here's a photo, cause I read the instructions wrong myself.
