When I origionally bought my R32 RB20DET 2.5years ago the first oil drop I found quite large chunks of gold looking bits of metal which were hard but were able to be crushed.
After several close oil changes the flecks appeared to dissapear with only the odd little tinny bit of gold fleck.
The gold fleck is definately still there and it has been 2.5years later and 90,000 hard km's of running 1.1bar of boost with lots of high rev's.
The engine is still perfectly quiet (160,000km's total), doesn't use oil and still goes as it did 2.5years ago.
What are these flecks. The head has previously been off (as seen by marks on head bolts) some gaskets appeared new etc.
Is it possible the engine had been rebuilt soon before I had purchased the car or is it simply a bearing failure of some kind that has hung in there?
https://www.sau.com.au/forums/topic/46770-gold-flecks-in-oil/
My money would be on a bearing wearing
(hey I'm a poet - and I didnt know it)
(I make rhymes all the times)
sorry about that
It would be hard to know for sure without stripping the motor (or at least the bottom end) but you may be lucky and get an idea if you have access to an endoscope
If its due a rebuild, you cant complain after that sort of use for that long. Just drive it till it goes :Bang: and then start the rebuild. :) (start collecting parts now)
Gold/Coppery metal bits usually indicates bearings...
Doesn't really matter anyway, just run it until it spins a bearing and then get it rebuilt. Nothing you can do at the moment, except maybe run a slightly thicker oil to slow down the wear...
New motor has already been built so no collecting of parts required :)
25de head ported polished, forged pistons, rb30 bottom end etc..
Only problem now is having time to take the car off the road.
If it wasn't for the paint shop saga the motor would have been in there these holidays.
Next oil drop (which I haven't done for 10,000kms as i'm getting slack with the ol' rb20) i'll take a few pics of the flecks or sometimes chunks of gold.
Then when I pull the motor down i'll take more pics of dud bearing.
Just a note, when I first got the car it was running Castrol Magnatec (yuk) and upon hitting the brakes hard I would get the oil light coming on.
Lots of oil changes later and this dissapeared.
Hey Joel,
My old vl turbo had the "gold glitter" problem too which was discovered when my oil pressure was tested and found to be very low(caused by faulty oil pump). Any way after a good 14 months after the new oil pump and many a thrashing its finally shat itself. I cant belive it took such a caining with no oil pressure, overheating and lots of revving....
Interesting..
Come to think of it when I first bought the car I was also having low oil pressure problems. Dropping almost to 0 after hard runs and for no reason when simply cruising. As I mentioned previously it would also cause the oil pressure light to come on when braking hard in to a corner.
It has since dissapeared after I ran Castrol GTX2 for quite a few weeks changing oil every week. This appeared to bring the oil pressure back to normal and the gold flecks have appeard to almost dissapear.
Since then I ran Penrite HPR10 and returned the oil changes back to every 5000km's unlike the previous 400-500km's every week.
  • 4 weeks later...
Though so.
My r32 GTR Didn't have an oil change for ages when I bought it.
After an oil change oil was still black!!!
This is very bad for engines, esp for Turbo's as I found out the hard way.
Anyway, I do the usual oil change every 5000k and filter at the same time because there is so much crap from not being changed for ages(not driven much by previous owner but caned when it was).
After around 2000k's one of the turbos decides to crap itself after a couple of high speed runs at 1.35 Bar.
The compressor is rubbing on the housing from bearings being stuffed.
My car had R33 n1 turbos already fitted, and since they are a ball bearing type I read somewhere that they don't like dirty oil and I think thats what has stuffed em. Now I gotta rip em out and fix em. I'm thinking of getting them rebuilt and highflowed.
Engine is still good, should do a compression test on it.
It runs a HKS f-con v pro piggyback computer. How hard are they to get tuned?
r33 n1 turbos are not ball bearing , i have them in my r33 very good turbos dont hi flow them , take them to garrett to have them rebuild .
Joel
You can buy oil test kits, they cost about $35 - $40. They are very informative and will tell you if there is any bearing wear. These kits are used by transport fleets as preventative maintenace, The test will pick up any fault before it actually breaks down.
If you do get one of these kits fill in the form with as much information as posible. i.e. Km's since oil change, recent repairs ect. then just put it in a post box and the results will be mailed back to you.
Kits available from most oil companys.
If you are in Perth I can get you one.
Regards
ASHLY
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
