When I origionally bought my R32 RB20DET 2.5years ago the first oil drop I found quite large chunks of gold looking bits of metal which were hard but were able to be crushed.
After several close oil changes the flecks appeared to dissapear with only the odd little tinny bit of gold fleck.
The gold fleck is definately still there and it has been 2.5years later and 90,000 hard km's of running 1.1bar of boost with lots of high rev's.
The engine is still perfectly quiet (160,000km's total), doesn't use oil and still goes as it did 2.5years ago.
What are these flecks. The head has previously been off (as seen by marks on head bolts) some gaskets appeared new etc.
Is it possible the engine had been rebuilt soon before I had purchased the car or is it simply a bearing failure of some kind that has hung in there?
https://www.sau.com.au/forums/topic/46770-gold-flecks-in-oil/
My money would be on a bearing wearing
(hey I'm a poet - and I didnt know it)
(I make rhymes all the times)
sorry about that
It would be hard to know for sure without stripping the motor (or at least the bottom end) but you may be lucky and get an idea if you have access to an endoscope
If its due a rebuild, you cant complain after that sort of use for that long. Just drive it till it goes :Bang: and then start the rebuild. :) (start collecting parts now)
Gold/Coppery metal bits usually indicates bearings...
Doesn't really matter anyway, just run it until it spins a bearing and then get it rebuilt. Nothing you can do at the moment, except maybe run a slightly thicker oil to slow down the wear...
New motor has already been built so no collecting of parts required :)
25de head ported polished, forged pistons, rb30 bottom end etc..
Only problem now is having time to take the car off the road.
If it wasn't for the paint shop saga the motor would have been in there these holidays.
Next oil drop (which I haven't done for 10,000kms as i'm getting slack with the ol' rb20) i'll take a few pics of the flecks or sometimes chunks of gold.
Then when I pull the motor down i'll take more pics of dud bearing.
Just a note, when I first got the car it was running Castrol Magnatec (yuk) and upon hitting the brakes hard I would get the oil light coming on.
Lots of oil changes later and this dissapeared.
Hey Joel,
My old vl turbo had the "gold glitter" problem too which was discovered when my oil pressure was tested and found to be very low(caused by faulty oil pump). Any way after a good 14 months after the new oil pump and many a thrashing its finally shat itself. I cant belive it took such a caining with no oil pressure, overheating and lots of revving....
Interesting..
Come to think of it when I first bought the car I was also having low oil pressure problems. Dropping almost to 0 after hard runs and for no reason when simply cruising. As I mentioned previously it would also cause the oil pressure light to come on when braking hard in to a corner.
It has since dissapeared after I ran Castrol GTX2 for quite a few weeks changing oil every week. This appeared to bring the oil pressure back to normal and the gold flecks have appeard to almost dissapear.
Since then I ran Penrite HPR10 and returned the oil changes back to every 5000km's unlike the previous 400-500km's every week.
  • 4 weeks later...
Though so.
My r32 GTR Didn't have an oil change for ages when I bought it.
After an oil change oil was still black!!!
This is very bad for engines, esp for Turbo's as I found out the hard way.
Anyway, I do the usual oil change every 5000k and filter at the same time because there is so much crap from not being changed for ages(not driven much by previous owner but caned when it was).
After around 2000k's one of the turbos decides to crap itself after a couple of high speed runs at 1.35 Bar.
The compressor is rubbing on the housing from bearings being stuffed.
My car had R33 n1 turbos already fitted, and since they are a ball bearing type I read somewhere that they don't like dirty oil and I think thats what has stuffed em. Now I gotta rip em out and fix em. I'm thinking of getting them rebuilt and highflowed.
Engine is still good, should do a compression test on it.
It runs a HKS f-con v pro piggyback computer. How hard are they to get tuned?
r33 n1 turbos are not ball bearing , i have them in my r33 very good turbos dont hi flow them , take them to garrett to have them rebuild .
Joel
You can buy oil test kits, they cost about $35 - $40. They are very informative and will tell you if there is any bearing wear. These kits are used by transport fleets as preventative maintenace, The test will pick up any fault before it actually breaks down.
If you do get one of these kits fill in the form with as much information as posible. i.e. Km's since oil change, recent repairs ect. then just put it in a post box and the results will be mailed back to you.
Kits available from most oil companys.
If you are in Perth I can get you one.
Regards
ASHLY
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
