These days i dont daily my gtr as i fly alot but the misso drives it to work regularly. Kinda expensive but she seems to enjoy it. Been up her lately as it has gone from an original 21000ks when we bought it to now just over 60000ks. Would love to keep ot under the magic 80000k mark
I used to daily my Bayside Blue GTT up until it was written off by a p plater.
Put over 30,000kms on it in just over a year...
I've since bought a replacement. But as my main form of transport is now public, I imagine this will see far less daily usage.
Just wind it back again...
9 hours ago, dr phil said:
So who has a mechanical lsd in their daily? What type, and how do you rate it?
It's more like a 'twice-weekly' than a daily but the R34 is our only car and has a Nismo 1.5-way in it. Hmm.... I'm learning to live with it but the diff is not great cold, or in the suburban shuffle in general. Some more impressions here: https://www.sau.com.au/forums/topic/466340-nismo-gt-vs-gt-pro-run-in-time/?do=findComment&comment=7779277
  • Like 1
KAAZ 1.5 way in my daily
Best modification I did to the car, and I've done a lot. The handling dynamics are chalk and cheese. With a 1.5 way the chassis listens to you - even on the limits it's point and steer as long as you're good with your throttle and brake inputs.
They are clunky for the first 2-3000km (read: someone repeatedly hitting the back of your car with a hammer when turning) but this gets significantly better as it beds in. Pro tip: ditch the stock 75w90 oil after run in (1000km) and use Penrite's 85w140 LS - it's thicker and quietens the diff, particularly after it gets hot. Don't need the clutches to bite so hard on the street. This goes for the Nismo 1.5 way too.
It's now very friendly and streetable - probably helps I've learned how to drive it smoothly too. Low speed turns out of slip lanes when off-boost can occasionally feel like driving a locker - this is the only hindrance I notice these days.
  • Like 2
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
