After a very long wait, Alex has piloted wreckedhead's 'JETT' to a 10.8 tonight at WSID.
Having some problems with the activation of the gas saw an early 11.1. But all this changed when the 50 shot kicked in and the 127mph terminal speed and 1.59 sec 60' time joined forces to produce the 10.8 he's waited for for so long.
With a relatively low mph, it's the 60' that does the talking here but wheelspin especially in the front is said to still be a big problem so slicks are the next order of the day and (I hope) a bigger shot of gas!
I'm assured that the timeslip will be scanned when he gets home from the strip and posted for us to drool over.
Well done wreckedhead, seriously impressed that it's finally here.
Adrian
https://www.sau.com.au/forums/topic/46773-jett-runs-10s/
  • Replies 163
thanks for the support guys, i finally got the pass i wanted, and on my birthday, what else could a person ask for. Ill scan my time slip in asap. and send it in, if only i had some traction on the front, and a little more on the back hopefully with the new set of slicks ill hit a low 10 hopefully.
good to see heaps of skylines at the creek, i saw gtr032 at the creek but sorry i didnt say hi, was all hyped up. next time
https://www.sau.com.au/forums/topic/46773-jett-runs-10s/#findComment-946655
mrblonde, i saw u last week run it sounded crazy! what mods have u done to it? and wat are u doing on on this forum of all places... are u part of dtm?
wreckhead thats fast on 20 inch chromies! lol did the pass with show and go eh.. happy birthday!
https://www.sau.com.au/forums/topic/46773-jett-runs-10s/#findComment-946715
Thanks. I've given it a really good clean (warm water only) and I always make sure the air conditioning is on a low setting before I launch.
What I'm doing on this forum is learning how to improve my ETs from other guys with late model fuel injected cars that run IRS!
https://www.sau.com.au/forums/topic/46773-jett-runs-10s/#findComment-946762
mate did Alex pilot the car for the 10.8 or yourself
i tried my luck at taking it down the track with the 50shop, but untill alex came and told me the gas was leaking out of the pressure gauge, we fixed the problem took the gauge off and he took it for its first proper drag with gas, after he run the 10.8 he got banned.
https://www.sau.com.au/forums/topic/46773-jett-runs-10s/#findComment-947288
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
