Dude, as I said those circuit slicks aren't going to do the job you want!
BFG DRs or drag slicks will however, and it's well documented what size DRs and what size drag slicks work on a GTR.
Remember the BFG gForce DRs in 17"/18" aren't what you want. You want the 15" BFG Comp TAs with nice big fat sidewalls (50/60/65 profile).
im gettting a set of 16in standard gtr wheels from bu5ter on the weekend, hopefully ill be able to get some 245 or 255 width, and 50 or 60 sidewalls. depending on what sizes bf goodrich make.
  • Replies 163
Guest two.06l
i have to go pic up the cage during the week, its mild steel so hopfully will be sufficiant.
the only problem is there is never enough hours in the day to get things done
who is supplying the cage and are they following the andra technical direction in its construction if so can we be given their details so we can get one too.cheers paul
correct x2. Make sure the cage is legal. ATM most of the cage makers are super busy and expensive with ppl building cars for WSID.
The guy I used is in the same complex as UAS about 4 shops back, cheapest approved cage I could find. Thats CAMS not ANDRA of course but he was doing ANDRA cars too I think.
You do not have to use Chrome Moly for your cage, but if you do then it must be tech inspected by ANDRA before painting. if you use mild steel the size required is larger than the CM equivalent.
It is true that most shops are flat out busy at the moment.
flaunting rulz is run, if they dont accept the cage then why should i spend another 2gs on a cage and more fuel just to race, changing the plates costs me hardly anything, i might not run another 10 ever again, so im not sure if its worth it.
Mate, I think you need to take the safety rules a fair bit more seriously. Not that running a non-ANDRA approved cage will cause you to crash but more that an attitude that ignores these saftey regs could.
And Doughboy, "...and you plow into a wall." isn't really an image any of us want. You made your point but I don't think that's the best way to do it.
Adrian
Oh sorry, I should have worded it "sneaks up and kisses the wall delicately". It's sad but only a graphic image is going to make people think about what could happen, especially in high speed motorsport. What about catapulting the car if the tailshaft snapped near the gearbox, or the transfer case/diff(s) locking up and make the car slide into the competitors lane and push that into a wall, or a flywheel exploding and loosing your feet etc. etc.
The rules are there for a reason, not to generate income in a cottage industry or to slow people down. Sometime you have to wonder what the consequences could be....
i already know what the consequences are, ive been around racing a long time, ive seen what can happen, i know rules and regs are there for peoples safety, but after i get a lower 10 i think ill give racing a miss for a while.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
