Dude, as I said those circuit slicks aren't going to do the job you want!
BFG DRs or drag slicks will however, and it's well documented what size DRs and what size drag slicks work on a GTR.
Remember the BFG gForce DRs in 17"/18" aren't what you want. You want the 15" BFG Comp TAs with nice big fat sidewalls (50/60/65 profile).
im gettting a set of 16in standard gtr wheels from bu5ter on the weekend, hopefully ill be able to get some 245 or 255 width, and 50 or 60 sidewalls. depending on what sizes bf goodrich make.
  • Replies 163
Guest two.06l
i have to go pic up the cage during the week, its mild steel so hopfully will be sufficiant.
the only problem is there is never enough hours in the day to get things done
who is supplying the cage and are they following the andra technical direction in its construction if so can we be given their details so we can get one too.cheers paul
correct x2. Make sure the cage is legal. ATM most of the cage makers are super busy and expensive with ppl building cars for WSID.
The guy I used is in the same complex as UAS about 4 shops back, cheapest approved cage I could find. Thats CAMS not ANDRA of course but he was doing ANDRA cars too I think.
You do not have to use Chrome Moly for your cage, but if you do then it must be tech inspected by ANDRA before painting. if you use mild steel the size required is larger than the CM equivalent.
It is true that most shops are flat out busy at the moment.
flaunting rulz is run, if they dont accept the cage then why should i spend another 2gs on a cage and more fuel just to race, changing the plates costs me hardly anything, i might not run another 10 ever again, so im not sure if its worth it.
Mate, I think you need to take the safety rules a fair bit more seriously. Not that running a non-ANDRA approved cage will cause you to crash but more that an attitude that ignores these saftey regs could.
And Doughboy, "...and you plow into a wall." isn't really an image any of us want. You made your point but I don't think that's the best way to do it.
Adrian
Oh sorry, I should have worded it "sneaks up and kisses the wall delicately". It's sad but only a graphic image is going to make people think about what could happen, especially in high speed motorsport. What about catapulting the car if the tailshaft snapped near the gearbox, or the transfer case/diff(s) locking up and make the car slide into the competitors lane and push that into a wall, or a flywheel exploding and loosing your feet etc. etc.
The rules are there for a reason, not to generate income in a cottage industry or to slow people down. Sometime you have to wonder what the consequences could be....
i already know what the consequences are, ive been around racing a long time, ive seen what can happen, i know rules and regs are there for peoples safety, but after i get a lower 10 i think ill give racing a miss for a while.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
