  • Replies 163
Yeah dood. I suggest you get in your car and attempt to run a 10 yourself. I don't understand what the point is in building it without driving it yourself? Get a cage as well, the safety rules are there for YOUR protection mate. But all in all, congratulations for great time your car ran :D
  • 1 month later...
Aside from all the whinging, bitching, sarcasm and snotty nosed childdren, whats the setup of the car, eg; internals, turbo, suspention setup, clutch, amout of boost run, ecu, power?.. I'm interested in what it takes to get an R32 GT-R into the tens. A thought, is $2000 roll cage worth more than your life, or your car? By the number of responses poeple are concerned for your safety matey, thought they're having a dig at you it seems alot of people care for your safety, get a proper cage.
Cheers :rofl:
i not worried if i pop my motor im ready to rebuild it now befor i go to the creek, i just dont have time as i am busy with work, but the time will come when i get a chance to head back down. Maybe i will beat his time( in my car) or maybe i wont, all the same its all good and fun.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
