RB25DET Neo into a R33 Gtst with 33 box
BundyBear
 Share
Hey Guys, My mate and I have just finished converting his R33 GTST to a RB25 Det Neo, so I thought Id doc the process and what we used of each car
Block, head, sump is all Neo
Inlet manifold is s1 with a cut n shut top half including throttlebody
exhaust manifold is aftermarket from the s1
enginemounts, we used the R33 ones but neo are the same
alternator, power steer, A/C are all s1 including the brackets
thermostat housing we used the 33 s1 part so we could use the same bottom hose but if u use the neo housing then just use a neo bottom hose
coilpacks we used the s1 packs as their only a few months old but they do not fit in the head valley so we made a bracket and mounted them elsewhere
WIRING CHANGES
vct plug needs swapping to a neo one or EV1 injector plug I beleive is the same
CAS wires need to be swaped...ie 1234 becomes 4321
thats it....because we used r33 stuff everything else stayed the same
pics to come
Edited by BundyBear
  • Like 1
Just for the record does anyone know if the VCT switch/valve is the same R33/R34 - aside from the electrical connection ?
Just may save some work if its a simple swap .
From the above I gather the coil and injector loom plugs are the same R33 to R34 .
Cheers A .
Edited by discopotato03
Cheers A .
Na we originally looked at pics in a few parts catalogs amd they look quite different. Our tuner also confirmed their not interchangable.. i just went to my local wreakers and snipped an injector plug of an old pulsar that had a dammaged harness (i dont like cutting plugs of a harness someone could use one day but if its Already munted then snip away). I wired it in leaving the old plug just incase but we wont go back to non-neo so the old one could have been cut off
Did the R34 injector sub loom plug into the R33 main harness . I know the coil one does .
Cheers A .
We used the inlet manifold, injecters and harness of the 33 so we minimised and wiring issues. I think my mates still got the neo inlet manny so we should be able to check the plugs
I used the R34 intake mani, had adaptor plate made for the iac stuff, throttle body vacumn channel welded up.  Theres a vacumn line from underneath that needs an extra fitting tapped into the neo plenum. The  top feed rail is obviously a bonus and the plenum gasket is better than the r33 one.
We already had an aftermarket top feed rail. So there was no great advantage we could see to running the 34 plenum given the extra work involved in using the 34 one.. which plenum gasket is better in the 34? The one between the two halfs or manny to head?. Did your injector harness plug straight into the 33 harness?
Neos are more efficient and definatly stronger than a s1 25. Ringlands, oil pump issues have been fixed (im sure neo arent perfect but better than the old ones). Were suspecting thr neo block is lighter as the car seems to sit a tad higher amd seems lighter in the steering. But thats pretty subjective...hopeing to get her on the rollers monday to get some numbers
  • Like 1
Well the old girls been dyno'd. seems we lost 40kw peak power but gained 40kw through the mid range. A bit disapointing but the extra mid range will make up for it in driveability. not sure why weve lost peak power as on paper we should have gained. compression is 150 across all 6 (dry and warm). Ive heard people say (since building it) the neo has slightly a slightly different intake diamiter so were planing on doing some measurements and maybe swapping the lower half of the intake to a neo and matching the cut n shut 33 top half and see what that does
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
