RB25DET Neo into a R33 Gtst with 33 box
Hey Guys, My mate and I have just finished converting his R33 GTST to a RB25 Det Neo, so I thought Id doc the process and what we used of each car
Block, head, sump is all Neo
Inlet manifold is s1 with a cut n shut top half including throttlebody
exhaust manifold is aftermarket from the s1
enginemounts, we used the R33 ones but neo are the same
alternator, power steer, A/C are all s1 including the brackets
thermostat housing we used the 33 s1 part so we could use the same bottom hose but if u use the neo housing then just use a neo bottom hose
coilpacks we used the s1 packs as their only a few months old but they do not fit in the head valley so we made a bracket and mounted them elsewhere
WIRING CHANGES
vct plug needs swapping to a neo one or EV1 injector plug I beleive is the same
CAS wires need to be swaped...ie 1234 becomes 4321
thats it....because we used r33 stuff everything else stayed the same
pics to come
Edited by BundyBear
  • Like 1
Just for the record does anyone know if the VCT switch/valve is the same R33/R34 - aside from the electrical connection ?
Just may save some work if its a simple swap .
From the above I gather the coil and injector loom plugs are the same R33 to R34 .
Cheers A .
Edited by discopotato03
Cheers A .
Na we originally looked at pics in a few parts catalogs amd they look quite different. Our tuner also confirmed their not interchangable.. i just went to my local wreakers and snipped an injector plug of an old pulsar that had a dammaged harness (i dont like cutting plugs of a harness someone could use one day but if its Already munted then snip away). I wired it in leaving the old plug just incase but we wont go back to non-neo so the old one could have been cut off
Did the R34 injector sub loom plug into the R33 main harness . I know the coil one does .
Cheers A .
We used the inlet manifold, injecters and harness of the 33 so we minimised and wiring issues. I think my mates still got the neo inlet manny so we should be able to check the plugs
I used the R34 intake mani, had adaptor plate made for the iac stuff, throttle body vacumn channel welded up.  Theres a vacumn line from underneath that needs an extra fitting tapped into the neo plenum. The  top feed rail is obviously a bonus and the plenum gasket is better than the r33 one.
We already had an aftermarket top feed rail. So there was no great advantage we could see to running the 34 plenum given the extra work involved in using the 34 one.. which plenum gasket is better in the 34? The one between the two halfs or manny to head?. Did your injector harness plug straight into the 33 harness?
Neos are more efficient and definatly stronger than a s1 25. Ringlands, oil pump issues have been fixed (im sure neo arent perfect but better than the old ones). Were suspecting thr neo block is lighter as the car seems to sit a tad higher amd seems lighter in the steering. But thats pretty subjective...hopeing to get her on the rollers monday to get some numbers
  • Like 1
Well the old girls been dyno'd. seems we lost 40kw peak power but gained 40kw through the mid range. A bit disapointing but the extra mid range will make up for it in driveability. not sure why weve lost peak power as on paper we should have gained. compression is 150 across all 6 (dry and warm). Ive heard people say (since building it) the neo has slightly a slightly different intake diamiter so were planing on doing some measurements and maybe swapping the lower half of the intake to a neo and matching the cut n shut 33 top half and see what that does
Definitely not fixed at all, oil pump engagement still to small with poor clearances still lots of failures just not as common as a slightly newer car
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
