New Comer from Bangladesh/UK
Hi All
I was participating in the forums from 2013-14 during my postgraduate studies. Back then started with R34 GTT and then replaced with a R33 GTR.
Last month migrated to AUS, based in Melbourne, VIC. Imported a '94 R32 GTR with a lot of Nismo goodies. (Will post separate thread about it later)
My goals for the Forum are as follows:
-meet some car enthusiasts
-source spare parts/accessories/etc
-seek advise on maintenance/tuning/troubleshoot
-gain further knowledge of R and S platforms
A bit about myself:
-Studied Automotive Engineering in UK
-Worked at GM and Jaguar Land Rover in UK
-Currently seeking engineering opportunities in AUS
Look forward to meeting some people in future meets.
  • Like 1
https://www.sau.com.au/forums/topic/467734-new-comer-from-bangladeshuk/
  • 2 months later...
Hi Guys
Here are the pictures of my R32 GTR landed in VIC.
The car comes with heaps of Nismo N1 Genuine Parts, seems like the previous owner in Japan basically made it identical to the N1 car.
Very straight body and probably had a respray in Japan at some point (hinting from the gloss paint finish) and a super tidy interior.
Please let me know your thoughts!
  • Like 4
Hi Guys
Sadly I think I have to let this go because of unemployment for the time being. Before selling, I'd like to keep the LMgt4 Wheels, Steering WHeel and Weldina Exhaust, as hopefully I will get another R32 when I am financially more stable.
I already got a set of R33 GTR wheels which is on the car right now. But need to find a set of Steering Wheel/Boss Kit or OEM Steering Wheel, plus an exhaust system.
Please let me know if any of you have these for sale?
  • 1 year later...
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
