lol I like the idea of an Evo, but it would be a chunk more spending for likely minimal gain over the current car.
I think an MX5 warrants a closer look, in terms of light, NA, and capable, it seems to top the charts.
In the meantime, as was suggested, I'll track the Silvia some more.
Edited by ActionDan
They vary widely like any car with multiple models across multiple years and types of usage.
The attraction there is that being lighter, and NA, the running costs (time and money) will be lower overall than another boosted tyre, fuel, and brake hungry beast.
I already have two of those :D
Here's a cool open wheeler,,, just across the ditch, dry sumped and lots of fruit. Left shifter for your convenience.
http://www.trademe.co.nz/motors/specialist-cars/competition-cars/auction-1202180099.htm
Cheers
Neil.
  • Like 1
  • 5 weeks later...
On 15/11/2016 at 8:52 PM, V28VX37 said:
I've been entertaining the idea of offloading the 34 though it's way too far gone in terms of time and cost over the past five years. It's the only car and keeping the balance between family friendly (=safe) and track friendly (=quick/reliable) is tough - I've just about tipped it over the edge with the 1.5-way. Sounds like DJBarnstar is familiar with that story :)
Anyway if you replaced it with a 2-car combo you could optimistically do a ~10k family diesel wagon (how exciting) and a ~10k track toy, but you don't get much for that money. MX5's are very appealing but a sorted turbo example wouldn't fit the budget. Though heaps lighter it'd be hard to go NA for the lack of power (at least on paper) but that said ditching the turbo would also mean reliability & heaps less ongoing cost.
I've been investigating the MX5 option a bit more just out of curiosity, window shopping is fun. There's heaps for sale on CarSales and mx5cartalk, and a few more track focused ones on my105 and TrackSales.
If I had the space for a trailer a well sorted racer (even non-turbo) would be sensible but since I don't it really would need to be registered. This would leave a couple of options:
  1. Club rego: Find an existing early NA project with mostly NB S1/S2 parts and other required track upgrades; ideally a turbo conversion too ;) There are a few around but many interstate, and getting them regoed in Vic is probably an engineering job = $$$
  2. Full rego: Find an NB (turbo) or NC that is registered but with a track focused setup. Newer car = theoretically less hassles but more rego cost
So essentially it's the good old 'streetable race car' dilemma, with a bit of 'is old but highly modified better than newer but more stock' thrown in.
Besides the purchase price a primary factor would be ongoing cost. I'd really prefer something that is reliable and cheap to track (haha oxymoron) over something that is fast but in bits half the time (already have one of those). If there was a measure it would be lowest $ per lap say over a year. Essentially, how to get the cheapest seat time?
Darn you Greg for making me think about this :huh:
An alternative which I don't think has been mentioned yet is something like a RX7 with a LSx engine, there have been a few conversions like that done so picking up a completed one is a possibility. But of course a decent one is going to cost a lot more than some of the other suggestions here. Thing is though you get a powerful, nice handling car that should be low maintenance, to each their own but running something like a MX5 would get boring real quick, there is no substitute for power and all the interesting challenges it brings to the track.
Nice. I'd love an LS swap for easy reliable power but never seen one on the street - I'm guessing they're pretty tough to get engineered?
I stupidly suggested to my gf that a MX5 would be a perfect car for her to get a head start in, learn on, use, etc.
Now I want one, with a small turbo albeit.
LS Swapped FD would be great, but if you want a ~1250-1350kg car with an easy to use 250-270kw then you start looking into options like, oh I dunno, a RX7.. or a jap turbo import made by Nissan...
I have this discussion with my housemate who got an E36 328i with plans to put a LS1 in.
  • Like 1
The OP is interested in NA options, he already has a turbo and the LS/RX7 conversion is popular because their rotor motor blows up regularly whereas a properly lubricated LS will go forever. The LS has other advantages too, low C of G, compact, parts availability, aftermarket support and relatively light in weight.
Sidetrack but the new owner is racing my old Monaro and it's onto its third or fourth LS now so they're not bulletproof either... Granted he's pushing close to 400rwkw naturally aspirated in a high G environment but still.
  • Like 1
58 minutes ago, 260DET said:
Lubrication. Other than abuse, pretty well every LS engine failure/premature wear situation can be traced back to inadequate lubrication.
Hundred percent. He's gone a dry sump setup now, hopefully less dramas in the future.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
