21 minutes ago, Coullsy said:
That's a fantastic idea, definitely a lot safer and more controlled then the PIT, but the non tethered style is a bit questionable
Why do you think its questionable? Just dangerous, causing a rear wheel lock?
3 hours ago, Coullsy said:
At high speed, a single wheel lock with an inexperienced driver, the chances of the car spearing off into other traffic would be quite high
What about an inexperienced driver being in a PIT maneuver.
4 minutes ago, Coullsy said:
This is true
That said, the ole PIT maneuver is not that common in AUS I don't think. Police round here tend to give up on chases before anybody gets hurt. I'm not an expert enough to have an opinion on what is the better approach. :ermm:
Quote
I think here in VIC there was talk of abandoning pursuits all together as a matter of safety. There was a bit of an uproar at the time, so I don't know if it was actually happened...
From memory there were a couple of serious incidents (crashes) that involved innocent 3rd parties so VicPol were looking to minimise this chance.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
