R33 Rb25det not performing
New to the forums not really sure if this is the right section to be posting in but I've spent several hours raiding the forums and can't find a solution anywhere.
I have an r33 rb25det it has a bigger fuel pump, front mount intercooler, super spark coils pack, 3.5" turbo back exhuast and a boost tee. It's running 0.74 bar of boost but it feels like it's not even boosting I can hear the turbo working and the gauges are reading 0.74 bar of boost. It smells like it's running real rich and has recently started to really chew through fuel. I have changed the spark plugs had them gapped correctly and the coil packs are 2 months old. What could be causing it to feel like it's not on boost and being real slow?
https://www.sau.com.au/forums/topic/467757-r33-rb25det-not-performing/
Get a wideband, and a fuel pressure gauge, actually these should already be in your car.
They help immensely when troubleshooting as you can drive down the road and help determine things like fuel filter, fuel pump, ignition issues etc. You can also see if your fuel pressure correlates with an issue in AFR, if they don't match than it could be an issue ECU/vaccum side. Rather than just opening the hood and looking for issue that can't be seen.
Get a tune. My rb25 drove like crap with similar mods, most 25s don't like to be changed from stock unless you get them tuned.
Question has been asked plenty of times, and it will come back to one thing. Tune!!
Maybe check the fuel lines on the pump didnt get confused, not sure on skyline pump but happened to me on a falcon and the vapor line got confused with the return line.  Long term result is now piston slap..
If the fuel pump is the walbro 430lph then that is most of your problem. Try running less boost (0.6 bar), cleaning the maf, check for vacuum leaks, etc.
But if the fuel pump is too big the regulator won't be able to adjust the pressure low enough.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
