R33 Rb25det not performing
New to the forums not really sure if this is the right section to be posting in but I've spent several hours raiding the forums and can't find a solution anywhere.
I have an r33 rb25det it has a bigger fuel pump, front mount intercooler, super spark coils pack, 3.5" turbo back exhuast and a boost tee. It's running 0.74 bar of boost but it feels like it's not even boosting I can hear the turbo working and the gauges are reading 0.74 bar of boost. It smells like it's running real rich and has recently started to really chew through fuel. I have changed the spark plugs had them gapped correctly and the coil packs are 2 months old. What could be causing it to feel like it's not on boost and being real slow?
https://www.sau.com.au/forums/topic/467757-r33-rb25det-not-performing/
Get a wideband, and a fuel pressure gauge, actually these should already be in your car.
They help immensely when troubleshooting as you can drive down the road and help determine things like fuel filter, fuel pump, ignition issues etc. You can also see if your fuel pressure correlates with an issue in AFR, if they don't match than it could be an issue ECU/vaccum side. Rather than just opening the hood and looking for issue that can't be seen.
Get a tune. My rb25 drove like crap with similar mods, most 25s don't like to be changed from stock unless you get them tuned.
Question has been asked plenty of times, and it will come back to one thing. Tune!!
Maybe check the fuel lines on the pump didnt get confused, not sure on skyline pump but happened to me on a falcon and the vapor line got confused with the return line.  Long term result is now piston slap..
If the fuel pump is the walbro 430lph then that is most of your problem. Try running less boost (0.6 bar), cleaning the maf, check for vacuum leaks, etc.
But if the fuel pump is too big the regulator won't be able to adjust the pressure low enough.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
