I drove a Porsche GT4
And I loved it.
large.20161103_172744.jpg.ffc99d1bbf266e
Holy smokes this car was amazing. I only had a small amount of time so I couldn't get it out of the city but it was so easy to drive it was still impressive at low speeds.
large.20161103_172816.jpg.9aeb6cba6c5f43
I don't think I got it into any gear above 3rd. This is partially because it sounded so amazing at 3 - 4k that cruising in 3rd was making me drool a little. The noise was just insane. Shifting down, despite it being a classic clutch activated shift, the car still revved up to match the gear. This took a little getting used to but after you did, it was quite welcome.
The interior was still very well equipped. I wasn't expecting much in the cabin, especially as though the doors have no inside handles, only straps (interesting given no other obvious interior weight loss or simplification.) The gauges were gorgeous and the rightmost "gauge" was a screen showing any of the computer data or the navigation.
large.20161103_172954.jpg.115de7bba509e2
The centre console was beautiful with a nice and responsive centre screen. Behind the gear knob were switches for ECS, Sport, Suspension settings and the exhaust butterfly (which I left open.) With the car in a 'normal' mode it is very comfortable and civilised. The seats are really low and quite difficult to get out of when you're as tall as I am. The alcantara steering wheel was just beautiful and contained no steering wheel mounted controls or buttons.
The shifter was very short which was nice, but it took me a long time to find reverse on the first few attempts. It is up to the left of first, but the channel to get it over there was very narrow and difficult to find. After a few attempts it became increasingly easy to find so maybe I just needed some practice.
But, as I am quite the brake-o-phile, I couldn't stop looking at them. Just look at them!!!
large.20161103_172716.jpg.9f84ad2d8f897e
See the rest of my pics here;
Here's a little driving video so you can hear it. If you just want the sound, watch from 1:00 onward.
What do you think? Does this float your boat?
  • Like 4
https://www.sau.com.au/forums/topic/467762-i-drove-a-porsche-gt4/
3 minutes ago, Aussie_Delivered_R32_GTR said:
Big ticket item now...........
New they are best part of $250,000,00.
Bob.
I just didn't get the price on it. It didn't strike me as a quarter-of-a-million-dollar car. $150k, yeah maybe, at a stretch, but no more than that.
Awesome. I have a soft spot for Porches especially the GT cars. It looks like it would have been super fun.
I get your brake enthusiasm, I have a real thing about car exhaust sounds, if I ever find myself with a spare few million I will be buying my garage based on the quality of the noise they make! (think LFA, Carrera GT, F458, E60 M5 so on, so on)
  • Like 1
    • Or get a guy in his early fiftys to do it. A single good "oof" and about two cracks from his lower back is about the right tightness...
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
