R33 boost spike issue
Hi all, I need to find a solution to fix a boost spike issue that my car has. It's a 1997 manual GTST, only mods are YJ coils, return flow FMIC, MBC and 3 inch turbo back exhaust.
Since I installed my front mount and dialled my boost up to 10/11 PSI I have noticed that when I punch it from 3.5 grand upwards the boost will spike to 12 or 13 PSI for a moment and then taper back to my set pressure. Just last night I installed a JJR bellmouth 3 inch dump pipe and now when I punch it, it will spike to 15 PSI! Would prefer not to launch my exhaust wheel out my exhaust, so I need to get this under control. Do I need an electronic boost controller or what?
https://www.sau.com.au/forums/topic/467794-r33-boost-spike-issue/
I have a cheap 'Drift' brand MBC - would be I correct in believing that this is a bleed type MBC? Would I benefit from changing to a ball type MBC such as this? http://www.ebay.com.au/itm/Turbotech-manual-turbo-boost-controller-THE-ORIGINAL-and-still-the-BEST-/321155544509?hash=item4ac65cb5bd:m:mJ5Yk12EnMVqXBuR8UxKxhQ
1 hour ago, jhjones said:
connect the wastegate actuator hose directly to the intercooler pipe and see what happens
Okay, I did this. I saw 5 PSI when easing into boost and around 6-7 when stomping it from higher revs. I had a thought: perhaps with the addition of my front mount intercooler, the extra volume that has to be pressurised before results in the opening of the wastegate being delayed? If this was the case, would relocating the barb from the cold side to the hot side fix this?
13 minutes ago, djvoodoo said:
Why don't you just turn the boost down via the MBC??
Probably would have achieved the same result what as post above suggested, but it's done now. :P
Just to be sure, the stock solenoid has been disconnected and the other hose blocked properly right? Getting 5 and 7 suggests the stock solenoid is still in use. Are your psi readings from an aftermarket gauge? Stock one is not psi.
Yes, actuator is connected straight to the nipple on the cold side of the intercooler piping, no stock solenoid. Readings are taken from an aftermarket boost gauge in PSI. The higher boost level that I'm getting isn't dependant on my RPM but rather how hard and fast the boost is coming on.
Edited by Custard
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
