Heads-up...its time to put it all together!
A Cometic MLS head-gasket is sandwiched in-between & now its time to finish it offIMG_9084.thumb.JPG.8e0ebcfedd0bbf22883fbd352678c50d.JPG
All assembled & ready to go - a cheeky ASR extended sump has also been given a new coat of paint & will hold 6.5ltrs of oil :)58e0ad20f346e_IMG_9088(noexif).thumb.jpg.3a50baaf2ea5787db0fb040d828ee0f4.jpg
Next steps are:
- Transfer the Alternator, P/S pump, Aircon compressor from the old rb20 & fit the shiny gtx3071.
- Remove the rb20 & gearbox and make space for the Neo and Rb25 gearbox which will be popping inside.
- Work out the wiring
Still so much to do....
  • Like 3
If your willing to spend the dollars I would get this for the wiring side
http://www.wiringspecialties.com/rb25-neo-wiring-harness-r32-gts/
Will do everything you need it to do, I also have all the wiring info somewhere on a hdd so let me know and ill pass it on
  • Like 1
Quick update on my growing stash of goodies ready to be installed :D
  • Garrett GTX 3071 gen2 - Provided by GCG Turbochargers
  • Nismo GT LSD 1.5way - Provided by Jesse Streeter
  • Nistune ER34 board with Stagea basemap - Provided by Nistune
  • Walbro 460L/h ethenol fuel pump - Provided by Scotty's Customs
  • Xspurt 1000cc (shot long nose) injectors - Provided by Scotty's Customs
  • Defi gauges - from facebook
  • Splitfire Coilpacks - from facebook
more to come...
  • Like 5
oooo ooo yummy, curious with your NEO what oil restrictors did you use? I've read the NEO block already has decent restrictors from factory and there's no need to run smaller.
1 hour ago, iruvyouskyrine said:
Neo has single 1.3mm from memory (was like 3 years ago). I put single 1.2mm in my 25/30 Neo.
I read someone said 1.27mm which is pretty much 1.3mm.. I should be good then :)
Running OEM :)
No big news - been trawling through blurry wiring diagrams for the r32 to prepare for the massive job of wiring in the rb25 neo.
I have heard stories of people losing power-steering when doing such conversions and I tried to get to the bottom of this...
It looks like the HICAS ecu controls the electronic power-steering solenoid.
This solenoid is driven by Speed-input; at low-speed there is more power steering assistance & at high speed its reduced.
It looks like the HICAS ecu requires 3x inputs - Speed, Tachometer & Neutral.
As long as those 3x inputs are still supplied to the HICAS ecu, then there should be no issues with Power steering! (fingers-crossed)
Not sure where these 3 inputs splice under the dash or next to the ecu...will need to follow some wiring within the car & see where they lead..
Hope to create my hybrid r34/r32 engine-loom this weekend - some further reading is still required.
  • 3 weeks later...
On 5/5/2017 at 1:43 PM, DaymoR32 said:
anymore updates on the hybrid loom?
Still working on it - have managed to map each wire on the Neo F3 plug as well as the r32 body plugs. Will attempt this weekend on the hybrid loom.
For those playing at home, found an easy method to repin the Neo F3 plug here -
  • Like 1
  • 3 weeks later...
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
