Heads-up...its time to put it all together!
A Cometic MLS head-gasket is sandwiched in-between & now its time to finish it offIMG_9084.thumb.JPG.8e0ebcfedd0bbf22883fbd352678c50d.JPG
All assembled & ready to go - a cheeky ASR extended sump has also been given a new coat of paint & will hold 6.5ltrs of oil :)58e0ad20f346e_IMG_9088(noexif).thumb.jpg.3a50baaf2ea5787db0fb040d828ee0f4.jpg
Next steps are:
- Transfer the Alternator, P/S pump, Aircon compressor from the old rb20 & fit the shiny gtx3071.
- Remove the rb20 & gearbox and make space for the Neo and Rb25 gearbox which will be popping inside.
- Work out the wiring
Still so much to do....
  • Like 3
If your willing to spend the dollars I would get this for the wiring side
http://www.wiringspecialties.com/rb25-neo-wiring-harness-r32-gts/
Will do everything you need it to do, I also have all the wiring info somewhere on a hdd so let me know and ill pass it on
  • Like 1
Quick update on my growing stash of goodies ready to be installed :D
  • Garrett GTX 3071 gen2 - Provided by GCG Turbochargers
  • Nismo GT LSD 1.5way - Provided by Jesse Streeter
  • Nistune ER34 board with Stagea basemap - Provided by Nistune
  • Walbro 460L/h ethenol fuel pump - Provided by Scotty's Customs
  • Xspurt 1000cc (shot long nose) injectors - Provided by Scotty's Customs
  • Defi gauges - from facebook
  • Splitfire Coilpacks - from facebook
more to come...
  • Like 5
oooo ooo yummy, curious with your NEO what oil restrictors did you use? I've read the NEO block already has decent restrictors from factory and there's no need to run smaller.
1 hour ago, iruvyouskyrine said:
Neo has single 1.3mm from memory (was like 3 years ago). I put single 1.2mm in my 25/30 Neo.
I read someone said 1.27mm which is pretty much 1.3mm.. I should be good then :)
Running OEM :)
No big news - been trawling through blurry wiring diagrams for the r32 to prepare for the massive job of wiring in the rb25 neo.
I have heard stories of people losing power-steering when doing such conversions and I tried to get to the bottom of this...
It looks like the HICAS ecu controls the electronic power-steering solenoid.
This solenoid is driven by Speed-input; at low-speed there is more power steering assistance & at high speed its reduced.
It looks like the HICAS ecu requires 3x inputs - Speed, Tachometer & Neutral.
As long as those 3x inputs are still supplied to the HICAS ecu, then there should be no issues with Power steering! (fingers-crossed)
Not sure where these 3 inputs splice under the dash or next to the ecu...will need to follow some wiring within the car & see where they lead..
Hope to create my hybrid r34/r32 engine-loom this weekend - some further reading is still required.
  • 3 weeks later...
On 5/5/2017 at 1:43 PM, DaymoR32 said:
anymore updates on the hybrid loom?
Still working on it - have managed to map each wire on the Neo F3 plug as well as the r32 body plugs. Will attempt this weekend on the hybrid loom.
For those playing at home, found an easy method to repin the Neo F3 plug here -
  • Like 1
  • 3 weeks later...
    • Have you tried another indicator stalk? Sometimes these go bad and cause issues.
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
