Heads-up...its time to put it all together!
A Cometic MLS head-gasket is sandwiched in-between & now its time to finish it offIMG_9084.thumb.JPG.8e0ebcfedd0bbf22883fbd352678c50d.JPG
All assembled & ready to go - a cheeky ASR extended sump has also been given a new coat of paint & will hold 6.5ltrs of oil :)58e0ad20f346e_IMG_9088(noexif).thumb.jpg.3a50baaf2ea5787db0fb040d828ee0f4.jpg
Next steps are:
- Transfer the Alternator, P/S pump, Aircon compressor from the old rb20 & fit the shiny gtx3071.
- Remove the rb20 & gearbox and make space for the Neo and Rb25 gearbox which will be popping inside.
- Work out the wiring
Still so much to do....
  • Like 3
If your willing to spend the dollars I would get this for the wiring side
http://www.wiringspecialties.com/rb25-neo-wiring-harness-r32-gts/
Will do everything you need it to do, I also have all the wiring info somewhere on a hdd so let me know and ill pass it on
  • Like 1
Quick update on my growing stash of goodies ready to be installed :D
  • Garrett GTX 3071 gen2 - Provided by GCG Turbochargers
  • Nismo GT LSD 1.5way - Provided by Jesse Streeter
  • Nistune ER34 board with Stagea basemap - Provided by Nistune
  • Walbro 460L/h ethenol fuel pump - Provided by Scotty's Customs
  • Xspurt 1000cc (shot long nose) injectors - Provided by Scotty's Customs
  • Defi gauges - from facebook
  • Splitfire Coilpacks - from facebook
more to come...
  • Like 5
oooo ooo yummy, curious with your NEO what oil restrictors did you use? I've read the NEO block already has decent restrictors from factory and there's no need to run smaller.
1 hour ago, iruvyouskyrine said:
Neo has single 1.3mm from memory (was like 3 years ago). I put single 1.2mm in my 25/30 Neo.
I read someone said 1.27mm which is pretty much 1.3mm.. I should be good then :)
Running OEM :)
No big news - been trawling through blurry wiring diagrams for the r32 to prepare for the massive job of wiring in the rb25 neo.
I have heard stories of people losing power-steering when doing such conversions and I tried to get to the bottom of this...
It looks like the HICAS ecu controls the electronic power-steering solenoid.
This solenoid is driven by Speed-input; at low-speed there is more power steering assistance & at high speed its reduced.
It looks like the HICAS ecu requires 3x inputs - Speed, Tachometer & Neutral.
As long as those 3x inputs are still supplied to the HICAS ecu, then there should be no issues with Power steering! (fingers-crossed)
Not sure where these 3 inputs splice under the dash or next to the ecu...will need to follow some wiring within the car & see where they lead..
Hope to create my hybrid r34/r32 engine-loom this weekend - some further reading is still required.
  • 3 weeks later...
On 5/5/2017 at 1:43 PM, DaymoR32 said:
anymore updates on the hybrid loom?
Still working on it - have managed to map each wire on the Neo F3 plug as well as the r32 body plugs. Will attempt this weekend on the hybrid loom.
For those playing at home, found an easy method to repin the Neo F3 plug here -
  • Like 1
  • 3 weeks later...
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
