Injector loom modified, injectors fitted, splitfire coilpacks fitted & engine loom wiring in progress...5947b1ec03160_enginewiring.thumb.jpg.f8cefb44982d82e0f6b0358dd8aa012e.jpg
Ditched the thermofans as they weren't really keeping temperatures under control, back to engine fan but a bit too close for my liking...
Have purchased GKTech engine fan which supposedly is thinner & more efficient (win-win) - on its way....
Dummy-fit the top intake manifold & Neo engine cover to see how it will all look. So far so good! Couple of hoses on their way from Japan to finish the intake plumbing...
Hopefully finish-off the wiring by next weekend & get the car ready for some intercooler, intake pipe & dump/front exhaust fabrication!
  • Like 1
Loving the progress, making me lean more and more to doing a neo rather than a standard RB25! you had any real difficulties with the wiring so far? or has it all been pretty straight forward?
  • Like 1
Wiring still in progress but a lot trickier than a s1 rb25 motor.
The neo loom has so many plugs for TCS, ABS, Sensors, Headlights, etc so its been slow progress to work out which to keep & which to cut.
So far, Ive worked out that the rb20 ecu grabs ignition voltage near the plug at the airbox and its a matter of wiring this to the brown eccs/ign relay & another pin on the ECU.
Im trying to make sure aircon, power steering, hicas, wipers & all dash switches/sensors work with the Neo so am tracing each wire to each plug and working through it slowly.
The Knock subloom on the r32 is separate and connects into the rb20 engine loom; whereas the Neo knock loom is integrated into the Alternator subloom; still working out best way to connect into the Neo loom.
  • Like 1
Working on all the little-bits to make the car go...
Time to flex!
Nothing beats new parts...replacing the coolant lines.
New clutch slave cylinder with custom hose
Tailshaft shortened, balanced & fitted.
Replaced the 30mm Turbo spacer with a 20mm spacer, much  better fitment now, hopefully the dump/front clear the aircon lines now...
With a 7ltr ASR extended sump, means more oil - bought enough for two changes & gearbox oil to suitoils.thumb.jpg.6e066d3e750d15669343cb30b8c2ae10.jpg
Hopefully next week we will be in a stage to fire-up and see if my wiring has been done right!
  • Like 5
On 7/14/2017 at 5:34 AM, rx-line said:
What compression pistons?
Specifications
Part Number: SC7297, 14028-6
Make: Nissan
Engine(s): RB25DET NEO
Year(s): 1998-2002
Piston Material: 2618 Aluminum
Bore Size: 86.50mm
Compression Ratio: 9.0:1 CR
Connecting Rod Material: 4340 Forged Steel
Connecting Rod Length: 121.50mm
Compression Height: 1.220"
Wiring loom finally sorted and Nistune + flex board soldered in.
Despite AFM plugged in, larger injectors on a stock map and no intake pipe connected, the engine cranked & started!
Car will be towed to fabricator and tuner on Monday, hopefully have a running car this Friday if all goes to plan :)
  • Like 4
Some fantastic work done by Havoc Fabrication, their attention to detail, care and professionalism is above all else. Thanks to their workshop for tackling this mammoth of a job.
  • Custom stainless steel intercooler piping with zero holes cut
  • Custom stainless steel intake pipe from z32 airbox
  • Custom stainless steel dump & front pipe with another cheeky o2 bung for wideband sensor/tuning
A couple of wiring gremlins to sort out last minute but the car is ready for run-in tuning this Monday :D
  • Like 6
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
