Track day maintenance schedule
Hello all!
This has always been an interesting topic for me, but not one I can find a lot of info on.
It would be great to get an idea of what kind of maintenance you guys do you on your cars each track day/race event.
I'm not sure if what I am doing is enough, or overkill, or if i'm missing something critical which is important.
I do mostly tarmac rally (up to 150km per day competitive) and some hill climbs/drifting/fun track days.
To try and keep consistency across info i'll use sub headings:
Frequency:
Work:
Frequency: Small service every event (events are either 1 or 2 days long) more major checks every 3-6 months or few events if I'm driving regularly
Work: Small service: Engine oil and filter, wheels off the car and quick check for leaks/loose bolts/rubber boots, top up fluids if required
Major service: Gearbox oil, brake/clutch fluid, thorough check of all bolts/inspection of parts for wear, pull out brake pads to check rotors/calipers etc
Yearly (if not already done within 12 months): Air filter, fuel filter, spark plugs, power steering fluid, coolant and diff oil (standard lsd)
Should I be doing things more or less often? What is your maintenance schedule like?
Cheers!
https://www.sau.com.au/forums/topic/467825-track-day-maintenance-schedule/
Every event - inspect brake pads, purge old fluid from calipers.  Spanner check caliper bolts, all suspension bolts.  Spanner check all exhaust manifold bolts, turbo fasteners. Check all I/C piping clamps. Check all exhaust system bolts, rubber hangers etc.  Scrape flange faces on hubs and wheels, remove any buildup.  Inspect rubber boots.  Stringline check of alignment, measure ride height (at each wheel).  Check shock absorber settings haven't been altered (mates or kids).
Every season (4 events for me, approx. 600 track km) - fresh engine oil, gearbox oil, diff oil. Full purge of new brake fluid for brakes and clutch.  Fuel filter inspect/clean (10 micron filter cleanable).  New spark plugs. Spanner check driveshaft bolts. Clean/reoil K&N air filter.
Every second season - fresh ATF for power steering. fresh coolant.
Always - look carefully at stuff and fix any obvious problem or something that is loose, vibrating, rattling.  Anywhere that is subjected to a lot of heat is where the most attention is focused.
None of this stuff is too hard, it's not like we are running gravel rallies.
  • Like 1
Now that my car is reliable at the track, all i do is;
- Keep an eye on pad material, and I like to have a spare new set as this allows me to use more of the pad before the change as I know if I did suddenly go all the way through, i can just put the new pads on. Brake fluid is bled regularly to keep the pedal feel. I never do a full flush as it cycles through quickly enough that i believe its not required. I have just done a full flush to change from Nulon to RBF600, as i want to avoid having to do any bleeding at the track.
- Re oil, I run Mobil1 0W-40 or Nulon 10W-40, and change it at maybe 3-4000kms - I will get it tested next time to see how its holding up. I overfill to the bump on the dipstick, and check/top up every session. For gear oils, full synthetics should be ok to be run at 3x the change interval you'd use for minerals. I only use full synth, and last did the gearbox at about 20,000kms, but it has been topped up due to shockproof's tendency to breath. Diff oil has probably been there for about 30,000km. I need to pull it out to do the bushes so will do it again when i do that. For power steer, since boiling fluid can be an issue, again use full synth due to the higher boiling point. I guess double the change interval over what you'd use for mineral. I dont think i've changed the power steer fluid for quite some time, but its never boiled and gets topped up a bit due to a leak in the rack.
- Coolant gets a really hard time, so do that every 10,000 and NEVER put any tap water in. IIRC a 6 liter green coolant pretty much fills it, so I dont think i add any water at all. Of course only distilled if required. Redline water wetter cools a little better than the usual stuff...
- Plugs get done whenever there's any imperfect running... Platinums have been fine for at least 40,000kms and coppers 15,000kms, but depends on usage and tune.
- I dont need to check for loose bolts anymore - just use the correct torque setting (and lube if specified) and they should never come loose unless there's a fundamental issue (eg AFAIK rb25 hot side can get loose in the long term).
- Just use feel and tyre wear to determine if there's any alignment issues.
Anyway - start with paranoia and check everything, and then once you know what stuff never goes bad, you can back off the checks that aren't required.
  • Like 2
  • 1 year later...
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
