FS: Xtreme 230mm Twin Plate Race Clutch - $1100
Selling: My near new award winning Xtreme 230mm Twin Plate Race Clutch
To suit R32 GTR's
Used: Around1000kms, maybe less. Hardly even used, no launches or ruff treatment, no hotspots etc
More meat than a butcher shop, more bite than a Pitbull.
Reason: Nismo Getrag 6speed conversion comes with Nismo Twin Plate. Being fitted :)
Price: $1100 + postage or pick-up welcome
($1650 new)
Link: http://www.xtremeclutch.com.au/en/product-range/clutch/ceramic-race-series/xtreme-230mm-twin-plate-race-clutch
PM me if your interested
Edited by Sinista32
To suit r32 GTR
1100kg Clamp Load
- Solid Ceramic Facings
- Solid Centered Clutch Plates
$1990 at Just Jap
Edited by Sinista32
Its Push :), Re_buildable, can be built up to around 1200hp
If you need pull and do the conversion it opens you up to possibilities,  where as if it where pull your limited.
 Des you will get a special discount for your work with SAU if you decide to buy :1311_thumbsup_tone2:
Price reduced to $900
Near new condition - Xtreme 230mm Twin Plate ceramic Race Clutch.
Easy to use.
To suit R32 GTR's (Push Type). Will suit other skyline models with Push clutch (32 GTS-t, R33 GTS-t's)
1100kg Clamp Load, Solid Ceramic Facings, Solid Centered Clutch Plates and can be rebuilt if/when the time comes
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
