End of No Limits Events
This is probably more pertinent to people in WA, but it has come to my attention that No Limits Car Club will be no more. It seems that they are unable to afford the hire fee of Barbagallo raceway and their event on 15 December 2016 will be the last. It also doesn't look like the RAC track will re-open, and with it goes the MC Motorsport State Sprint Championship. This means that two of the major events which amateur drivers have enjoyed for years will come to an end. It is really disappointing to see this sort of thing happen and its even sadder when our state government sits back and does nothing to support these sorts of events. The state government is always going on about how it strives to make our roads safer but its efforts to do so are primitive and one dimensional. Their only response is to continue to draft draconian road legislation and to exorbitantly penalize any car enthusiast who dares to enjoy their car on a public road. However, when it comes to supporting events such as the no limits events on Thursday nights at Barbagallo, where enthusiasts have a chance to enjoy their cars in a safe and controlled environment, state and local government do nothing by way of support. It is disgusting. I am truly sad and disappointed by the state of motorsport in WA and even more disappointed in our government representatives who seem useless when it comes to supporting these sorts of events.
  • Like 2
https://www.sau.com.au/forums/topic/467837-end-of-no-limits-events/
State governments support sport with $ to varying degrees, depending on what it is and how many people are involved. Sounds a bit silly for the owners of Barbagello to price themselves out of the market but then again perhaps racers don't want to pay a realistic entry fee. Generally speaking by world standards we in AU have had it on the cheap in the past.
+ 1  to all of this is not good at any level
From people with a normal street car that wants to punt it around a track safely, a guy I was talking to spent 3 years and all of his hard earned $ just finished his s13 silvia and was his first event out last month to me who uses it as both my monthly 'night out' and good track time where there is timing and use it as my 'time attack' development
I don't know if it will help or not but I have put my hand up to the people that run it to help in anyway I can including extra $ to increase the potential for them to keep the events alive !
Edited by bcozican
It's a real shame but there's always the WASCC events (race tuning days etc), AFRCC do track days, etc. etc.. No Limits wasn't the be all and end all!
totally agree not be all and end all for sure... I do tuning days and all that
for me right now I want to get times.... Its just what I want to do. And Id rather rather get 35+ laps timed in 4 hours on a Thurs night than at a speed event approx. 25 laps that literally takes all day
bang for your buck couldn't beat it for the average punter
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
