Zrbsliding Posted November 22, 2016 Share Posted November 22, 2016 Ken's z31 I wanna go fast build I am Ken from the Seattle area USA. I bought my 1985 300zx GLL non turbo 5 speed in 2011 with the impression it had blown head gaskets which only an RB swap would remedy. I replaced the bad thermostat and drove it for 4 years. Opportunities arose and I purchased a wrecked 87 300zx with what I assumed was a stock rb20 silver top and 5 speed swap for $800 usd. Car had been sitting for 6 years after the owner wrecked. 1 Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/ Share on other sites More sharing options...
PranK Posted November 22, 2016 Share Posted November 22, 2016 Looking forward to this. wtf happened to the thumbsup emoti ?!? Need to investigate. Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793217 Share on other sites More sharing options...
PranK Posted November 22, 2016 Share Posted November 22, 2016 Oh he's back ... Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793218 Share on other sites More sharing options...
Zrbsliding Posted November 22, 2016 Author Share Posted November 22, 2016 Engine was siezed so I started to take it apart. What I found blew me away. Internal: .015" over custom Wiesco pistons spool rods full balanced rotating assembly oil snout to pressure plate spec stage 3 6 puck sprung clutch and flywheel acl bearings hks step 1 cams 264/264 adjustable cam gears and greddy timing belt bolt on: rc racing 750cc injectors precission 5557e dual ball bearing with billet wheel z32 maf aeromotive fpr Nistune type 2 board The list of parts well exceeded my $800 paid for the siezed block. I discovered the heard was ported by a hydroplane mechanic. I have no idea as to what power the car made or what psi the tune was done at. All the info I have is the car ran for two weeks and then it was totaled. Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793222 Share on other sites More sharing options...
Zrbsliding Posted November 22, 2016 Author Share Posted November 22, 2016 Wheels were ordered 17x9 +20 because stock wouldn't grip well once it's running again. New block fitted with Pistons. Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793249 Share on other sites More sharing options...
Zrbsliding Posted November 22, 2016 Author Share Posted November 22, 2016 Got the engine put back together and installed then trailered the project 50 miles home to be finished. Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793259 Share on other sites More sharing options...
Zrbsliding Posted November 22, 2016 Author Share Posted November 22, 2016 Built some one piece intercooler piping because I don't care for couplers. 4 couplers is a party any more makes a head ache. 1 Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793261 Share on other sites More sharing options...
Zrbsliding Posted November 22, 2016 Author Share Posted November 22, 2016 Modded the plenum to reduce overall piping. Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793262 Share on other sites More sharing options...
Zrbsliding Posted November 22, 2016 Author Share Posted November 22, 2016 Welded in a nipple for the iacc and Aacv as well as a flange for the synapse engineering synchronic bov. Also a 3 core s13 radiator modded to fit and a custom made shroud for the 14" fan. Unsure on cfm but the shop who built the car for the previous owner had used an oem vgz31 radiator and shroud with this fan tucked inside very crudely. Lower coolant hose is fitted with a temp switch for the fan relay. 1 Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793291 Share on other sites More sharing options...
Zrbsliding Posted November 22, 2016 Author Share Posted November 22, 2016 The z31 hvac system is totally vacuum actuated. Because I do not like the idea of trying to wire in a vacuum pump to cope with boost I decided the whole lot will get ripped out and tossed. 1 Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793292 Share on other sites More sharing options...
Zrbsliding Posted November 22, 2016 Author Share Posted November 22, 2016 Also when the previous owner of my 85 had taken the car in for diagnostic the brilliant mechanic decided to dump head gasket stop leak into the system and I did not want to chance the heater core to fail and fill my fresh rb and radiator with stop leak. Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793293 Share on other sites More sharing options...
Zrbsliding Posted November 22, 2016 Author Share Posted November 22, 2016 (edited) I'll be fitting a 40,000 btu unit from jegs racing which has a 300cfm 3 speed fan blower built in. For $180 is piece of mind that I would not have heating issues. Edited November 22, 2016 by Zrbsliding Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793294 Share on other sites More sharing options...
PranK Posted November 22, 2016 Share Posted November 22, 2016 This is awesome. I'd love to see more pics of your fabrication. Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793320 Share on other sites More sharing options...
Zrbsliding Posted November 23, 2016 Author Share Posted November 23, 2016 I'll see what I can find relating to my z31. The pics below are some modded arms and drop spindle for a mates aristo. 1 Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793364 Share on other sites More sharing options...
PranK Posted November 23, 2016 Share Posted November 23, 2016 Thats awesome. Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793365 Share on other sites More sharing options...
Zrbsliding Posted November 23, 2016 Author Share Posted November 23, 2016 Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793366 Share on other sites More sharing options...
Zrbsliding Posted November 23, 2016 Author Share Posted November 23, 2016 (edited) I chopped the filler neck off due to fabbing a breather tank for the system. Edited November 23, 2016 by Zrbsliding Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793367 Share on other sites More sharing options...
Zrbsliding Posted November 23, 2016 Author Share Posted November 23, 2016 1 Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793370 Share on other sites More sharing options...
Zrbsliding Posted November 23, 2016 Author Share Posted November 23, 2016 Some s13 modded Lcas and knuckles for a mate. 1 Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793371 Share on other sites More sharing options...
Zrbsliding Posted November 23, 2016 Author Share Posted November 23, 2016 (edited) My Z has modded knuckles, running s13 Lcas and tie rods with the rack moved forward 25mm to prevent over centering. Of course I have no pictures of my own parts. S13 coil overs front and rear and s14 tension rods. Welded diff and poly bushings but one day will have s13 subframe. I will attempt to snag some photos in the day light. Edited November 23, 2016 by Zrbsliding Link to comment https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/#findComment-7793372 Share on other sites More sharing options...
