Mohsen Posted November 24, 2016 Share Posted November 24, 2016 built RB26 87mm pistons, fruity built rb26 engine built by engine action in flemington has approx under 10,000kms, only did one track day- was a 33 degree day and did not go over 85 degrees with a stock GTR radiator made 280kw on 16psi (did have some issues that were narrowed down to some air leaks) bottom end: R33 Long nose crank block, cradle, crank and rods inspected, machined and hot tanked arp rod bolts fitted to the rods, crankshaft machined, balanced, unplugged and cleaned and replugged 87mm cp piston and ring sets, ACL race series main and rod bearings standard oil pump reconditioned with a billet gear added gates timing belt head has been hardness and vacuum tested and has had a standard refresh, all valves reseatedm new guides etc. torqued down with permaseal rod bolts (oem) on a MLS steel head gasket. engine covers painted BMW sepang bronze, with a pearl through it. includes RB26 sump modified to suit a RWD application, alternator, power steering pump AC gear is not available $8000 ono Motor never let me down, made it to sydney and back in summer with no hiccups. only has a few minor oil leaks. which i think are from incorrectly fitted seals (by a mechanic i chose due to convenience, and not experience!) ps: i can remove the head and sump for interested parties for a thorough inspection. invoice is available for the motor build. all you need to do is bolt on some turbos and away you go Link to comment https://www.sau.com.au/forums/topic/467872-built-rb26-87mm-pistons-bnr34-turbos/ Share on other sites More sharing options...
Mohsen Posted November 29, 2016 Author Share Posted November 29, 2016 r34 gtr turbos r34 gtr turbos good condition minimal shaft play does not include drains and lines $500 + post located in thomastown victoria call or message 0411421097 also have built motor available. Link to comment https://www.sau.com.au/forums/topic/467872-built-rb26-87mm-pistons-bnr34-turbos/#findComment-7794583 Share on other sites More sharing options...
Mohsen Posted November 29, 2016 Author Share Posted November 29, 2016 can also include R34 GTR Turbos etc for a better deal. only selling as ive bought a GTR and having a new motor built- because i can. Link to comment https://www.sau.com.au/forums/topic/467872-built-rb26-87mm-pistons-bnr34-turbos/#findComment-7794931 Share on other sites More sharing options...
