viper2002 Posted November 24, 2016 Share Posted November 24, 2016 R34 GTT Traction Control, SLIP and Engine light on Hi guys, A few days ago when I was driving I noticed that the Traction Control OFF, SLIP and Engine Light had all turned on all of a sudden. The car didn't drive any differently (no miss-fires, performance loss or anything) so it seems something else is up. I disconnected the battery and re-connected it which temporarily stopped the issue for a few minutes (this was after a cold start however), but now it's back. Any ideas what it could be? I've done some research and some people are saying throttle bottle (I've checked the cables), coil packs (these were brand new only a few years ago) and a few other things, but there is no definite answer. How can I go about getting this fixed? I don't want to fork out $500 on coil packs only for it to not be the issue. Thanks! Picture for reference: Link to comment https://www.sau.com.au/forums/topic/467880-r34-gtt-traction-control-slip-and-engine-light-on/ Share on other sites More sharing options...
GTR-32U Posted November 24, 2016 Share Posted November 24, 2016 have you had the fault codes checked ? My guess is it's coming up as fault 21 - ignition. In which case your coil packs are faulty 1 Link to comment https://www.sau.com.au/forums/topic/467880-r34-gtt-traction-control-slip-and-engine-light-on/#findComment-7793655 Share on other sites More sharing options...
V28VX37 Posted November 24, 2016 Share Posted November 24, 2016 Yep check your fault codes: http://www.sau.com.au/forums/topic/266512-reading-nissan-fault-codes-ecu-fault-codes-how-read-them/ My car throws TCS + SLIP ever since the manual conversion, no more traction control but oh well. I also get engine light on after disconnecting the CAS, have you done that recently? Resetting the ECU using Nissan DataScan (or a paperclip) clears this error. You could try unplugging and reconnecting the TPS too just to see if that makes any difference. 1 Link to comment https://www.sau.com.au/forums/topic/467880-r34-gtt-traction-control-slip-and-engine-light-on/#findComment-7793659 Share on other sites More sharing options...
viper2002 Posted November 24, 2016 Author Share Posted November 24, 2016 Thanks, it appears to be Error 21 - Ignition Failure. I take it the coils need replacing? Heres a video: https://sendvid.com/4igwqnx0 Link to comment https://www.sau.com.au/forums/topic/467880-r34-gtt-traction-control-slip-and-engine-light-on/#findComment-7793679 Share on other sites More sharing options...
V28VX37 Posted November 24, 2016 Share Posted November 24, 2016 Could try spark plugs first, also replacing the harness can help. But yes probably time for new coil packs. Link to comment https://www.sau.com.au/forums/topic/467880-r34-gtt-traction-control-slip-and-engine-light-on/#findComment-7793717 Share on other sites More sharing options...
viper2002 Posted November 25, 2016 Author Share Posted November 25, 2016 Ahh damn, anywhere in Melbourne where I can pick up Splitfires? Or do I need to order them online? Link to comment https://www.sau.com.au/forums/topic/467880-r34-gtt-traction-control-slip-and-engine-light-on/#findComment-7793832 Share on other sites More sharing options...
GTR-32U Posted November 25, 2016 Share Posted November 25, 2016 just jap has them at a good price...maybe they can freight them to you Link to comment https://www.sau.com.au/forums/topic/467880-r34-gtt-traction-control-slip-and-engine-light-on/#findComment-7793929 Share on other sites More sharing options...
Watermouse Posted November 26, 2016 Share Posted November 26, 2016 I had same fault signs with my car, replaced with splitfires now all good ? 2 Link to comment https://www.sau.com.au/forums/topic/467880-r34-gtt-traction-control-slip-and-engine-light-on/#findComment-7793978 Share on other sites More sharing options...
Kinks Posted December 9, 2016 Share Posted December 9, 2016 The magical pixies in the standard ECU are smarter than you give them credit for. I was getting fault code 21 for a couple of weeks for no apparent reason and then suddenly I lost a cylinder at light cruise. That cylinder would then come and go intermittently. Replaced coil packs with a brightly coloured aftermarket brand, and they seemed OK until a dyno day when they started misfiring. Replaced with Splitfires, and they've been great. Link to comment https://www.sau.com.au/forums/topic/467880-r34-gtt-traction-control-slip-and-engine-light-on/#findComment-7797348 Share on other sites More sharing options...
