Picked up the short motor last weekend. I supplied the L24 front sump and oil pickup as the L28 has a rear facing sump and oil pickup so the block needed to be modified to suit.
I also had a clutch supplied with the motor as the flywheel face has been designed around the pressure plate and it’s balanced with flywheel. It's a a single plate unit consisting of a 2600lbs AP pressure plate with an Exedy organic race clutch plate, built by Jim Berry in QLD.
I've listed my Mikuni 44mm carbs and LD28 crank for sale and once they move I'll send the short motor back with the P90 head to be completed. I spoke with Jenvey about the 48mm heritage bodies and they wont be in production until March so I'll follow up then.
  • Like 3
  • 3 weeks later...
  • 1 month later...
Update time... The body is now booked in with Custom and Classic Cars for body work but probably wont be started until the end of this year due to the work they have on. I've seen quite a few projects they've worked on including another C110 and 240Z and the craftsmanship is outstanding so I'm confident the car is in good hands.
C110 -https://www.facebook.com/pg/CustomAndClassicCars/photos/?tab=album&album_id=522151214472678
240Z - https://www.facebook.com/pg/CustomAndClassicCars/photos/?tab=album&album_id=1328888837132241
I purchased the body kit from Restored which includes the over fenders, rear wing and chin spoiler and a few more missing rubber seals.
The other big purchase is the fully built P90 head to match my 3.3ltr short block. Turns out that Locky from LCR is taking a different direction with his 240Z (matching numbers L24) and offered me the head that was built to match. Specs are:
  • New 46mm Stainless Intake Valves.
  • New 35mm Stainless Exhaust Valves.
  • New Valve Guides.
  • Refaced Rockers.
  • High-side Steel Retainers.
  • HSD valve springs.
  • 54.5cc Chambers.
  • Manifold face has been drilled & tapped for an LCR external coolant rail - blanking plates included.
  • Injector notches have been welded up.
  • New Freeze Plug.
  • New Nissan Oil Gallery Plugs.
  • New Nissan Rocker Cover gasket.
  • New Kameari MLS Head Gasket.
  • Near-new Rear Collant outlet
  • Water Jet Blasted Head & Tappet Cover.
Ported by Les Collins at LCR Racing, Intake port flow (average): 228cfm @ 28" of H20 on a 90mm bore plate. This head flows enough to make 380hp at the flywheel so it should be a very strong motor for a little C110.
  • Like 4
  • 1 month later...
  • 11 months later...
So, I hope you're sitting down for this news... I'm dropping the car off for body work next weekend! It's finally happening. The shell will go on a trailer and I'll do a weekend road trip to SA. There will be lots of progress shots on body work and I'll be busy again with the car.
  • Like 3
I made the 1500km round trip from Melbourne to Mt Barker in South Australia over the weekend to drop the car off for body work. ETA on the job is approx 8-12 months but I should get some regular updates which I'll post. There is lots to do whilst I'm waiting, engine assembly, sourcing induction and ECU, gearbox, diff, suspension brakes etc. All of the running gear will need to be blasted and painted and there is lots of work to do on the final parts removed like the heater, aircon, steering column....
Getting a non rolling shell on a trailer is pretty tricky work!
We left super early for the 9 hour drive
The car looked a little sad sitting there but it's in very good hands
I dropped the GTR grill off for reassembly and painting and the GTR rear panel too as it's painted in acrylic at the moment.
On 27/04/2018 at 12:31 PM, Adzmax said:
lolol my favourite line
"Serious buyers only! I can’t stress this enough I know what these are worth. Don’t waist my time"
  • Like 1
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
