don't take this the wrong way...but I hope all that work is costing a fortune.
what a prick of a job to go to everyday.
Haha, I think we both know the answer to that question. Maybe they get pleasure form seeing something shitty come out better than new? [emoji38]
  • 3 months later...
Progress has been slow becuase the media blaster has been backed up with a large commercial job. There were a few more areas that needed work once the ass end was off. Here's some more progress shots from before it went off. The car arrived back last week so it should start moving now.
  • 3 weeks later...
The rear end has been fully repaired and is back together, firs the boot floor had to be welded back into place
Then the inner and outer beaver panels could be reattached
Once that was done the 1/4 panels were temporarily fitted to line up the tail light panel
The end result is a slightly more compete rear profile!
  • Like 1
The right hand sill was pretty much gone so it was far quicker to have an entire replacement section made.
And the old sill removed with the inner tidied up ready for the section to be welded in place.
As much as I appreciate the car (she's going to be amazing) I read through this whole thing and gotta say; I appreciate your dedication and patience more so! Pulling out stuff you purchased near decades ago, I wouldn't even remember I had that stuff!
Thanks mate! It's funny you say that becuase when I pulled out old boxes to catalogue I found things I'd forgotten about. It's all in a spreadsheet now ;)
19 hours ago, Adzmax said:
Restored make some parts but it's all FRP stuff. I'm not aware of any steel products?
AH true most the ones I know are Hako parts. These guys do side steps and some chrome bits for kenmeri - http://www.n-classiccar-jp.com/parts2.html but not much else. Could be something on Yahoo but seems like you have the sides sorted already
That's awesome! So much Hako stuff about in general, they are much better in terms of parts than the C110.
The wheel tubs have been modified by manufacturing a new outer tub as per the genuine GTR. Once the flares are bolted on they will easily fit the deep dished Hayashi Racing wheels.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
