don't take this the wrong way...but I hope all that work is costing a fortune.
what a prick of a job to go to everyday.
Haha, I think we both know the answer to that question. Maybe they get pleasure form seeing something shitty come out better than new? [emoji38]
  • 3 months later...
Progress has been slow becuase the media blaster has been backed up with a large commercial job. There were a few more areas that needed work once the ass end was off. Here's some more progress shots from before it went off. The car arrived back last week so it should start moving now.
  • 3 weeks later...
The rear end has been fully repaired and is back together, firs the boot floor had to be welded back into place
Then the inner and outer beaver panels could be reattached
Once that was done the 1/4 panels were temporarily fitted to line up the tail light panel
The end result is a slightly more compete rear profile!
  • Like 1
The right hand sill was pretty much gone so it was far quicker to have an entire replacement section made.
And the old sill removed with the inner tidied up ready for the section to be welded in place.
As much as I appreciate the car (she's going to be amazing) I read through this whole thing and gotta say; I appreciate your dedication and patience more so! Pulling out stuff you purchased near decades ago, I wouldn't even remember I had that stuff!
Thanks mate! It's funny you say that becuase when I pulled out old boxes to catalogue I found things I'd forgotten about. It's all in a spreadsheet now ;)
19 hours ago, Adzmax said:
Restored make some parts but it's all FRP stuff. I'm not aware of any steel products?
AH true most the ones I know are Hako parts. These guys do side steps and some chrome bits for kenmeri - http://www.n-classiccar-jp.com/parts2.html but not much else. Could be something on Yahoo but seems like you have the sides sorted already
That's awesome! So much Hako stuff about in general, they are much better in terms of parts than the C110.
The wheel tubs have been modified by manufacturing a new outer tub as per the genuine GTR. Once the flares are bolted on they will easily fit the deep dished Hayashi Racing wheels.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
