I've been a bit slack on updates! With the tubs done the guards needed repair and modification for the flares. The flares were trial fitted in order to get the correct positioning for the mounting hardware and panel modification.
  • Like 1
The base of both guards was pretty bad but no real surprises there considering it was fairly heavily bogged. Replacement sections were constructed then welded in place. The flares were also trial fitted, mounting hardware was welded in behind the guard to make attachment nice and neat.
  • Like 5
1 hour ago, Tenny said:
Awesome work mate. I've just started restoring an R32 GTR myself. (I say restoring but its more like painting and re-assembling haha).
Glad I don't have to go to this effort. You are definitely doing this properly!
I was just having a read of your thread actually, should be nice man. Yeah definitely be thankful you don't need to go to this effort, it hurts haha :)
With all of the panels, doors and skins now rust free the car is FINALLY rust free. This is a major milestone and really exciting! The roof skin, rear and and quarter panels are all welded back into place and aligned nicely. There is still work to to but it's looking like a car again.
  • Like 3
9 minutes ago, mr_rbman said:
Is this one of those projects where you knew what you were getting into from the start or has it just snowballed the more you delved?!?
Good question... I think I always knew that old Nissan/Datsun was a can of worms but the difficult part is you don't really know just how big the can is until you blast the shell. The shell was pretty bad, lots of hidden gems but I'm in so deep now that the only thing to do is to finish it. It will be worth it in the end...*nervous laughter*
  • Like 2
So now the body is done the fun stuff begins. The guards have to be modified to fit the JDM spec fender mirrors. This is the "template" used
The holes didn't need to be anywhere as large, this is the grommet that sits between the body work and mirror
With the holes cut the mirrors were mounted up for test fitment, looking good!
I see a lot of restos at work, but this is genuinely right up there with the best of them!
Especially these days, to cut out rust and hand-beat those panels with body lines and all is a dying art; and to my primitive hands, absolute witchcraft!
Fantastic work mate! Can't wait to see it progress :D
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
