I've been a bit slack on updates! With the tubs done the guards needed repair and modification for the flares. The flares were trial fitted in order to get the correct positioning for the mounting hardware and panel modification.
  • Like 1
The base of both guards was pretty bad but no real surprises there considering it was fairly heavily bogged. Replacement sections were constructed then welded in place. The flares were also trial fitted, mounting hardware was welded in behind the guard to make attachment nice and neat.
  • Like 4
1 hour ago, Tenny said:
Awesome work mate. I've just started restoring an R32 GTR myself. (I say restoring but its more like painting and re-assembling haha).
Glad I don't have to go to this effort. You are definitely doing this properly!
I was just having a read of your thread actually, should be nice man. Yeah definitely be thankful you don't need to go to this effort, it hurts haha :)
With all of the panels, doors and skins now rust free the car is FINALLY rust free. This is a major milestone and really exciting! The roof skin, rear and and quarter panels are all welded back into place and aligned nicely. There is still work to to but it's looking like a car again.
  • Like 3
9 minutes ago, mr_rbman said:
Is this one of those projects where you knew what you were getting into from the start or has it just snowballed the more you delved?!?
Good question... I think I always knew that old Nissan/Datsun was a can of worms but the difficult part is you don't really know just how big the can is until you blast the shell. The shell was pretty bad, lots of hidden gems but I'm in so deep now that the only thing to do is to finish it. It will be worth it in the end...*nervous laughter*
  • Like 2
So now the body is done the fun stuff begins. The guards have to be modified to fit the JDM spec fender mirrors. This is the "template" used
The holes didn't need to be anywhere as large, this is the grommet that sits between the body work and mirror
With the holes cut the mirrors were mounted up for test fitment, looking good!
I see a lot of restos at work, but this is genuinely right up there with the best of them!
Especially these days, to cut out rust and hand-beat those panels with body lines and all is a dying art; and to my primitive hands, absolute witchcraft!
Fantastic work mate! Can't wait to see it progress :D
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
