Picked up the short motor last weekend. I supplied the L24 front sump and oil pickup as the L28 has a rear facing sump and oil pickup so the block needed to be modified to suit.
I also had a clutch supplied with the motor as the flywheel face has been designed around the pressure plate and it’s balanced with flywheel. It's a a single plate unit consisting of a 2600lbs AP pressure plate with an Exedy organic race clutch plate, built by Jim Berry in QLD.
I've listed my Mikuni 44mm carbs and LD28 crank for sale and once they move I'll send the short motor back with the P90 head to be completed. I spoke with Jenvey about the 48mm heritage bodies and they wont be in production until March so I'll follow up then.
  • Like 3
  • 3 weeks later...
  • 1 month later...
Update time... The body is now booked in with Custom and Classic Cars for body work but probably wont be started until the end of this year due to the work they have on. I've seen quite a few projects they've worked on including another C110 and 240Z and the craftsmanship is outstanding so I'm confident the car is in good hands.
C110 -https://www.facebook.com/pg/CustomAndClassicCars/photos/?tab=album&album_id=522151214472678
240Z - https://www.facebook.com/pg/CustomAndClassicCars/photos/?tab=album&album_id=1328888837132241
I purchased the body kit from Restored which includes the over fenders, rear wing and chin spoiler and a few more missing rubber seals.
The other big purchase is the fully built P90 head to match my 3.3ltr short block. Turns out that Locky from LCR is taking a different direction with his 240Z (matching numbers L24) and offered me the head that was built to match. Specs are:
  • New 46mm Stainless Intake Valves.
  • New 35mm Stainless Exhaust Valves.
  • New Valve Guides.
  • Refaced Rockers.
  • High-side Steel Retainers.
  • HSD valve springs.
  • 54.5cc Chambers.
  • Manifold face has been drilled & tapped for an LCR external coolant rail - blanking plates included.
  • Injector notches have been welded up.
  • New Freeze Plug.
  • New Nissan Oil Gallery Plugs.
  • New Nissan Rocker Cover gasket.
  • New Kameari MLS Head Gasket.
  • Near-new Rear Collant outlet
  • Water Jet Blasted Head & Tappet Cover.
Ported by Les Collins at LCR Racing, Intake port flow (average): 228cfm @ 28" of H20 on a 90mm bore plate. This head flows enough to make 380hp at the flywheel so it should be a very strong motor for a little C110.
  • Like 4
  • 1 month later...
  • 11 months later...
So, I hope you're sitting down for this news... I'm dropping the car off for body work next weekend! It's finally happening. The shell will go on a trailer and I'll do a weekend road trip to SA. There will be lots of progress shots on body work and I'll be busy again with the car.
  • Like 3
I made the 1500km round trip from Melbourne to Mt Barker in South Australia over the weekend to drop the car off for body work. ETA on the job is approx 8-12 months but I should get some regular updates which I'll post. There is lots to do whilst I'm waiting, engine assembly, sourcing induction and ECU, gearbox, diff, suspension brakes etc. All of the running gear will need to be blasted and painted and there is lots of work to do on the final parts removed like the heater, aircon, steering column....
Getting a non rolling shell on a trailer is pretty tricky work!
We left super early for the 9 hour drive
The car looked a little sad sitting there but it's in very good hands
I dropped the GTR grill off for reassembly and painting and the GTR rear panel too as it's painted in acrylic at the moment.
On 27/04/2018 at 12:31 PM, Adzmax said:
lolol my favourite line
"Serious buyers only! I can’t stress this enough I know what these are worth. Don’t waist my time"
  • Like 1
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
