Stagea M35 Pearl White
Up for sale is a 2002 Stagea M35
It has been our family car for the last 8 years. It has been one of the best cars we have owned. Now it is time to move on.
Details,
Nissan Stagea M35
Pearl White
181000kms
High flow turbo form Bill at ATS
Scotty dump pipe
DVD player, TV tuner with Dual head rest monitors, English Conversion (The first one to be converted in SA) Should ad value
Reverse camera, parking cameras in front bumper
Factory cruise control
Dual Sunroof
Racing Heart 18X8 mags with fairly new tyres
Interior is fairly tidy with a few marks in the boot.
The Bad,
The suspension is quiet but it is very soft and bouncy,
Leaks a bit of oil around the rocker covers,
Back bumper needs painting or body kit,
1 or 2 of the window switches are intermittent
It has seen a lot of car parks and has a few door marks down the side
Price is $6000
Contact Brad zero four two seven 999093
https://www.sau.com.au/forums/topic/467884-stagea-m35-pearl-white-6000/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
