R33 Parts
Selling some parts to suit a s1 rb25det. All were in working condition when removed
Full manual conversion kit, everything except the gearbox
flywheel, clutch,tailshaft etc $200
Tomei Pon Cams - straight drop in cams $500
Blitz sbc id - dual solenoid with 4 boost settings $300
Splitfire could pack $300
Located in Seven hills
0416 035 195
https://www.sau.com.au/forums/topic/467886-r33-parts/
  • 4 weeks later...
  • 3 weeks later...
  • 4 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
