NEWBIE INTRO
Hey, I'm Amy, new to this forum - recently purchased 2x JDM S15s (1 is a donor and 1 is tubbed) to rebuild with my better half, however he has now deployed for 9 months, and asked me to wait til he comes home before making the build! So, in the last week a GTS 4 R33 dropped into my lap, which I was told has ?blown motor, but likely just low compression (hopefully! I haven't started my seek and find exploration yet) that will be my "her rebuild" project while James is away. Time is on my side.. so no rush! I've been doing some research on what to do with this block.. options options options! To rebuild and leave as is RB25DE; turbo the DE with a bolt on myself, or just remove the DE and drop a DET package... Looking forward to any advice and guidance - always willing to learn and hear from people who've done one of these options, or have the knowledge - please share it!
  • Like 1
https://www.sau.com.au/forums/topic/467895-newbie-intro/
Welcome @SHRED1 ! Thats a nice little familia of Nissans you have there! I'm just a little jealous! [emoji4]
:welcome:
Thanks man! Definantly an accumulation.. I need deeper pockets to fun these builds haha
https://www.sau.com.au/forums/topic/467895-newbie-intro/#findComment-7794318
    • The correct answer is body colour. Admittedly it does look pretty handsome as-is in grey.
    • I'm surprised there isn't any interest in this.
    • Por qué no los dos? Body colour red with black stripes down centre, onto bonnet and bootlid.
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
