Yellow Jackets Ignitor Module and general ignitor module questions
Hi All,
Keeping this short, I'm chasing a misfire when on boost.
Replaced the plugs.  Interesting found BCPR7ES-11 in there from the last mechanic, no big deal.  Anyhow, replaced with BCPR6ES-11.
The air box has been out/in recently, Will check it's gone back on properly tomorrow with some light.  Maybe it is un-metered air.  I hope it's not the AFMs, been through 6 sets...
But, I have a feeling it is the 20+ year old coil packs and/or ignitor module.  Found this (awesome!) video on how to test the ignitor module, again I'll give it a crack tomorrow.
So, here are a few quesitons:
Sort of off topic-ish.. sort of.
24 minutes ago, admS15 said:
Those plugs have a 1.1mm gap. Try decreasing the gap to 0.7 -0.8 and see if misfire goes away.
I've skimmed the threads, people going from 1.1mm to 8mm gaps and vice-versa fixing problems (or not!).  I figured that having a timing tune and exhaust with no extra boost keeping the stock 1.1mm gap would be fine.  Anyhow, I hear you and it is on the list.
Here's my misfire diagnosis thread for some inspiration: http://www.sau.com.au/forums/topic/326043-resolved-misfire-in-r34-gtt-rb25det-neo/
Also in the early days I had a significant breakdown beyond 4000rpm, which turned out to be a broken CAS
The more power/torque you make the more difficult it is for the spark to jump across the plug gap. Missfire on boost is classic underpowered ignition. So you either need to add more electric power to the plugs, or make the gap shorter. Since closing the gap is free, its a good place to start for diagnosis. You can also inspect the plugs while they're out to see if they are consistently coloured, which should help diagnose if some coilpacks are weaker than others. Also check that the coils are seeing the full ~14.5V, because less volts on the primary solenoid means less volts at the secondary solenoid and therefore less volts at the plug.
Thanks @MrStabby and @V28VX37.  Somehow this double posted mid typing.  Here is what I found (and posted in the other thread here):
Testing as per the above, pins (cylinders) 1 to 6 tested at 500 ohms +/- 10 ohms per pin.  What raised an eye brown, the video tested at 8 Mohms.  The two units are waaayyyy different but who knows which one is right.  It would be good for some more results.
Testing in reverse. each pin read open - sweet.
Here is where things start getting interesting.  Quoting the electronics buff who's multimeters we used, we were testing the "forward junction voltage on the base emitter" - this isn't covered in the above video and honestly, nfi, but it sounds good.   Pins 1 to 5 read 1.2v.  Pin 6 read 0.6v.  Testing across three multimeters and a transistor reader, this was consistent.  Then, all of a sudden, all pins started reading 0.7v.
So, something is wrong here and I ordered a refub unit.
Yeah I've tried measuring stacks of coil packs over the years, typically none the wiser. Hunting random misfires is part of the game owning an RB, I never had any issues with my previous LS1 even though it pushed more power naturally aspirated than my RB does with forced induction...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
