CAS sensor problem
Hi guys,
Advance timing = anti clockwise rotation on cas = higher timing value on pfc
Retard = clockwise = lower timing value
Right?
The issue is, my pfc reads lower timing when i advance , and higher value when i retard.
Will this point out to a faulty CAS or wiring between the 2 signal wires swapped around ?
my mechanic recently did an FFP upgrade and he messed around with some of the wirings, because he wanted to tidy up the engine bay.
Hoping if any can shed some light if its a simple as just swapping the wires or should i replace the cas?
https://www.sau.com.au/forums/topic/467907-cas-sensor-problem/
yea is starts fine. just troubleshooting a weird high rpm misfire. but i finally got arround to figuring this cam timing vs crank timing .
Retard = clockwise
applies to cam timing
Advance timing = clockwise rotation
Retard = anti clockwise
is for crank.
the cas is a crank angle sensor mounted onto the cam. therefore advance is clockwise.
and i just learn that the service manual says advance -
Quote
Because the further before tdc the spark plug fires the more advanced it is as its occurring earlyer on in the cycle
Edited by Dev RB25
High rpm misfire first place I would go to is plugs. Then to coil packs and ignitor if that didn't fix it.
When you get the high rpm misfire is it only WOT or are you able to Rev past at partial throttle with no issue?
also moving the cas does not change the timing on the PowerFC..
you need to sync what the PowerFC is telling the car to do... playing around with the CAS blinding will result in this scenario:
  • PowerFC tells motor 15
  • Motor is actually at 25
  • Go on boost, and blow motor because you're 10 degrees more than what you're supposed to be at
Yes, you will now say "but the PowerFC numbers are changing as I play with the CAS" - that is correct as you play with the cas your motor behaves differently and then jumps into a different cell which may have a timing value of 20 degrees.. that is what you're reading.
  • Like 1
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
