RB25DET Whistling
Hey all.
I've recently had an a new issue with the RB25det in my Series 1 C34 Stagea. Last week I changed the plugs and coils, which solved the misfire problems I was having. After getting everything back together I'm now getting what I can only describe as a 'kettle whistle' it's noticable from 70km/h and quite loud at 100km/h ( a speed in which the car drives at a lot), and I do get slight hints of it at around 60km/h.
Tonight after double checking the plugs it did feel like it wasn't boosting as much as it normally did.
I put in Irridium sparkplugs, and Splitefire coils.
Have doubled checked all connections and everything appears to have a good connection, and couldn't spot any lines with fatigued lines.
Wanting to know if you guys could suggest anything to check.
Mods to car;
3inch split pipe dump
3 inch ehaust, but retaining the stock 2inch cat
GFB plumb back BOV
K&N Pod filter
Return flow front mount intercooler
Turbo smart bleed valve set to boost the car to about 9-10psi
All these mods have been on the car for at least 3 weeks before the whistling started, and was planning to remove the bleed valve, and put the factory diverter valve back on tomorrow morning before I need the car for work.
https://www.sau.com.au/forums/topic/467920-rb25det-whistling/
Exhaust gasket is my first guess. Mine sounded exactly like this and got worse and worse. One time it was the turbo gasket and the second time was the exhaust manifold gasket.
Does volume increase with RPM?
If its speed dependant not rpm or engine load/boost dependant, i would say something is physically making the noise, like a panel gap or something hanging down/out
Your post gives the impression it is only related to speed
That was my first thought, especially as I've installed a CB radio, and cut up the front bar for the intercooler.
Since writing the post I've pretty much lost all boosting ability, not even getting wastegate pressure (5psi) now, got a spare turbo laying around so gonna change the turbo later this arvo.
The exhaust has new OEM gaskets from the turbo through to the front of the cat when I put in the 3inch dump and front pipe and I can't hear any exhaust leaks.
The only exhaust gaskets that matter when it comes to whistling noises and ability (or lack thereof) to make boost are on the high pressure side.  That's manifold to head and manifold to turbo.  And as I said before, they won't whistle like you describe if you're running at low load at a given speed.  You need exhaust manifold pressure to make them scream.
You can also get whistles from boost leaks.  Again though, they won't whistle at a constant road speed - only when you have pressure inside.  But if you do have some stupidly large gaping hole in your inlet tract then you could get all sorts of weird noises and apparent inability to make boost.  And probably lean running off boost and rich running on boost and all the bad things that can happen as a result of those.
You can get weird noises from the turbo if the turbine is falling apart, which can lead to loss of ability to make boost.  They normally fail totally in a split second though.
All in all, we still can't diagnose this one across the 'net.
While that is not good, It's on the suction side so will not stop the car boosting - unless the open pipe (if thats how you found it) has sucked something into the turbo and 're-adjusted' the comp wheel
Pull your suction pipe of and check the turbo for damage and shaft play etc. It is usually fairly obvious when you have a turbo issue.
  • Like 1
I took that photo after removing that hose, just sitting there as point of reference as to where it came.
The compressor wheel is good, very little shaft play and spins freely. Yet to check the turbine as I'm aware they can end up in the cat.
6 hours ago, KiwiRS4T said:
Start by pressure testing the inlet system. Its hard to spot some boost leaks.
Sadly, I don't have the equipment to test pressure and compression. The downside about moving out of home :P
13 hours ago, KiwiRS4T said:
Bit off topic but why on earth would you fit a 3in exhaust and restrict it with a 2in cat?
I hadn't gotten around to that, it was actually my plan to fix that within the next couple weeks. That's about it really.
I did also notice that when I stopped getting boost the normal turbo spool noises wasn't happening. Turbo will be out tomorrow so I can check that and the manifold properly.
No worries
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
