R34 GTR suspension settings?
Has anyone got the factory specs for comparison?
Also what would be recommended for a street car that's only driven occasionally.
Has coilovers, (BC ER whichare quite firm) looks like subframe collars and a rear sway bar, 275 rubber. 110mm at the lowest point (mid muffler), Upper arms look stock from a quick glance.
1 minute ago, ActionDan said:
I was looking at going MCA as I know BC are just cheap coilovers but these look to be in very good condition and "work" for now.
I do suggest doing research on both brands. I think you'll find that the components from both brands come from the same factory overseas.
There are some variances between the two brands though.
16 hours ago, ActionDan said:
Care to share more on this? That's a pretty big claim, though to be fair, parts coming from the same factory means nothing in terms of what specs those parts are created with.
I'm just saying they're essentially the same coilover using the same components, but are obviously built to different specs depending on the kit choice. Custom modifications can be made from both brands.
I would like some evidence of this?
Comparing the 2, they are of completely different construction....
14 hours ago, ActionDan said:
Yeah found that, only answers one part of my question.
Below is my set up based loosely on suggestions from SK. The Stagea has basically the same set up as GTR. ( For track only I change the front camber to neg 3deg which works great but is no good on the road)
Nissan Stagea RS4T
Front
    Before Target
Caster Left   positive 6 degrees
  Right   positive 5.75 degrees
Camber Left   1.5 degree negative
  Right   1.5 degree negative
Toe in Left   1mm toe out
  Right   1mm toe out
Rear
Camber Left   Negative 2.0 degrees
  Right   Negative 2.0 degrees
Toe in Left   0-1mm
  Right   0-1mm
1 hour ago, ActionDan said:
Thanks, that's about what I was expecting with the exception of more neg rear camber than front?
Yep for street use (on my wagon) - you may want to progressively increase it from zero to see what's best for you.
Was gonna ask the same question as I thought it was odd. I generally only run between 1-1.5 on the rear.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
