Car won't go into gear when running?
So car was working fine when I parked it all gears worked fine, parked it for about a month, tried to drive it today and none of the gears will go in unless you push real hard and when you do they grind... Also when you push down the clutch all the way it takes like 10 seconds to go back up... So Im guessing the clutch is not being released so I checked the clutch reservoir and it was empty and there was a tiny leak from the hose which connects to where the clutch is. So I topped up the clutch fluid and it still doesnt work. Could anyone tell me how to fix this I will greatly appreciate it
https://www.sau.com.au/forums/topic/467950-car-wont-go-into-gear-when-running/
Just now, admS15 said:
You need to replace the hose with the hole in it and then bleed the clutch and all will be well. Google how to bleed clutch for instructions.
Yeah I got a decent guide on how to bleed it. Ok thanks alot mate I will come back if it still doenst work
Is this the hose I pull off to bleed the clutch?  15271245_1526991027314830_1842666427_o.jpg?oh=9862daeb05aefcad057d6acafa1bf8a1&oe=584005CE
11 minutes ago, admS15 said:
If that is the one with the hole in it, you need to change it with a new or 2nd hand good one. You then bleed it from the nipple above the hose in your pic.
So i replaced that hose but Im having trouble finding a clutch bleed tutorial for the r32.
Currently im using this method :
So do i follow that method using the nipple you told me?
Here is the tutorial for bleeding the slave cylinder.
Also what I did was pulled the slave off the trans. cracked the bleeder and pushed the plunger all the way in, hold all the way in and then close bleeder and plunger will slowly return back...did that a couple times and never had an issue since.
Edited by Ed.williams5
  • Like 1
I have a question, so in the guide it says "the bleed must be done at every hose connection" so where are the other connections other than the the nipple on the cylinder?
Also does anyone know where to buy that hose I pulled off? Went to two repcos and an enzed and they all didnt have it
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
