How to launch/burn out in NM35 Stagea?
As per thread title and also want to keep the wagon forum alive ......
Might sounds d*mb but how do you launch/stall or do a burnt out in the Stagea? I drive manual cars since the day i got my license .... some 20 years ago ... god damn it i'm old :(. Do you put in manual mode, 1st gear then launch? Same apply to burnt out?
Gotta replace the 2 rear tyres soon so might as well have some fun first, in a controlled environment offcourse.
Car has brake cut mod, hi-flow
Cheers
Well it's 4wd so unless you drop the front axels or can pull out a plug or something you might not have much luck, I know those things work for C34 but not sure about M35
To launch, (manual mode)hold brake down hard and I mean hard. Accelerator to the floor and wait. Should start spooling after 5 or so seconds, hold it there for a bit then release the brake and feel all that heavenly glory of your head slamming into the headrest. It works that way with a stock turbo. Don't know how the Highflow will go. What Highflow? For burnout, you'll most probably need to drop the front drive shaft.
  • Like 1
Shite
This don't sounds good with Kakimoto exhaust. I have had many 4wd launches in the old gtr, i understand what you meant about heavenly glory, look at my signature :).
I got Sierra hi-flow, stag 1 from previous info as i didn't arrange the works myself.
Quote
Make sure the brake cut is doing its thing (IE, so signal to the ECU) Manual in first, left foot on the brake and right foot to the floor and wait.
With the stock turbo it'll eventually start turning the rears a little after a while, not too sure about the highflow, though I've normally launched by then.
As for a burnout I find the old pump the brake to kill  the attessa works fine, I dont do it very often (so far a whole of twice since I bought the car) so any issue of pressure being in the center diff is neither here nor there. 4 pumps then hold for the 5th as you start the car, 4WD light will come on and youre good to go.
  • Like 1
Pump the brake to kill attessa is NEW, i've never heard of this.
Have you tuned your car yet?
Khoa
Its how you bleed the attessa system IIRC? Read about it many moons ago.
Just running an Impul, you saw my car down at scotts the other week. Its pretty stock, just the impul, exhaust and FMIC, and a plenum spacer really in the way of power mods.
  • Like 1
Oh for some reasons, i thought i heard you have Emanage ready to go in.
I do, its sitting on the floor in my bedroom ready to go.
Need to scrounge some cash together to install it, I'm broke as shit right now.
Maybe its 5 pumps? every time I've tried it its worked, I tried it randomly one night while at a skid pan, thought I'd give it a crack. Not 100% sure as I went from memory. Someone a bit more educated should probably weigh in
  • Like 2
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
