BOV leak? Induction sound help!!
Hi skyline aficionados.
I am fairly new in Aus and recently I bought a r33 s1 gtst rb25det.
About a week ago I was cruising around and a cop pulled me over, the usual story, drivers license, open the bonnet etc (ok, I wasn't cruising)
Everything was good until he gave me a yellow sticker, this was new to me, who would have thought that in Aus the cops are also mechanics..
Anyway, today I took the car to the pits and it failed because of missing mesh in IC, tyres with low tread a pod filter without permit and a blow off valve.
All of the above can be fixed quite easily with the exception of the blow off valve..
The engine is practically stock, just have aftermarket IC, the pod and the boost valve is bypassed, the blow off valve is stock.
The car does indeed have a massive induction noise, which is why the inspector complained..
I don't need to rev a lot to start hearing that induction sound and at some times (seems to be only in constant rpm) the sound seems to be slightly metallic, if I just push the throttle the sound keeps going up until I lift it and i ear normal turbo flutter, not the pigeon sound just the normal decompression.
Could this be the stock BOV leaking? a boost leak? the pod filter??
The only odd thing that I see is the boost valve bypass, its not the usual grounding the black wire and leave the hoses.
Instead I have the wastegate connected directly to the hose that comes from the turbo and goes to the IC, the top connector on the valve has nothing on it and the bottom one is connected to the intake (after the IC) will post some pics later.
Long story short I just want the noise gone otherwise i might as well ask for a job at the pits since i'll be there all the time.
Since this is my first post and I feel bad to ask without giving something I OCR'ed the entire R33 manual to make it search friendly (will make another post)
https://drive.google.com/file/d/0B2fI6rThQ1T9YTZaT1JfN3IxekU/view?usp=sharing
Thank you all
Edited by nuno12345
https://www.sau.com.au/forums/topic/467967-bov-leak-induction-sound-help/
check to see if the bov has been blocked. People put a piece of tin at the bottom of the bov to block it and make it do pigeon noises. Replacing the pod filter with a factory airbox will also reduce any induction noise and flutter.
  • Like 1
Get a boost gauge. Your boost may or may not be above normal - either way you need to know. And as above get a stock airbox - less noise, same power, less hassle..... and check your BOV
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
